Harbor Freight Lift - Road Glide Forums
post #1 of 19 (permalink) Old 10-06-2013, 04:34 PM Thread Starter
Harbor Freight Lift
Not sure if this is the proper place but...Picked up a Harbor Freight lift, upgraded it with their "Condor" style wheel chock and had to pick up a piece of 1" steel at Tractor Supply to replace the lock bar it comes with...
STG246 is offline
post #2 of 19 (permalink) Old 10-06-2013, 04:37 PM
willbo22's Avatar
Nice lift. And nice bicycle. ;-)
Sent from my SGH-T769
And Justice For All...
willbo22 is offline
post #3 of 19 (permalink) Old 10-06-2013, 04:40 PM
sj01fltri's Avatar
I have the same lift,used the flip up wheel chock,had to shorten the back loop about an inch it was on the fender,got the two year warranty,may have to use it,its leaking hyd fluid
sj01fltri is offline
post #4 of 19 (permalink) Old 10-06-2013, 05:08 PM Thread Starter
This is the 2nd one I got, the first one puked hyd fluid all over the floor the first time I stepped on the pedal to raise it...For about $350 total it works good for me...The bicycle is my wifes, springer front end! LOL
Ryan
STG246 is offline
post #5 of 19 (permalink) Old 10-06-2013, 05:19 PM
I have the exact set up but I cut notches in the side lip (about an 1" from the front of the lift) so the condor T-member would sit in them and be flush with the bottom. This added a little more security for me.
2016 CVO Road Glide
SMSgt B is offline
post #6 of 19 (permalink) Old 10-06-2013, 05:42 PM
Even with the chock I would strap that nice glide to the rings on the side just in case.
1982 FLT Virgin unmolested barn find.
1983 FXDG 80th Anniversary AKA Willie G Disc Glide, 10.5 to 1, Andrews B grind, 2002 Fat boy carb, Barnett Clutch, drag pipes.
2003 FLTSCI Black and Silver converted with Motor Trike Kit plus HD tour pak, 88 inch, HD 204 Cam, Vance & Hines mid shots.
AzHogRider is offline
post #7 of 19 (permalink) Old 10-08-2013, 09:41 PM Thread Starter
I was thinking about that, but with it positioned like I have it, the rear drop out will work for changing rear tires etc. I do plan to make some stiffeners to go from the table to the chock "arms" to stiffen it up.
Ryan
STG246 is offline
post #8 of 19 (permalink) Old 10-08-2013, 09:52 PM
Well my motorcycle floor jack exploded a few days ago. I Had been looking at this and other lifts to replace it but someone please answer a question for me.
What do you do when you are doing tire repairs or replacements. How do you get the wheels off the ground for removal? That is involved in most of my maintaince.
Tom
Lord Help me to be the Man my Dog thinks I am!
TearlessTom is offline
post #9 of 19 (permalink) Old 10-08-2013, 10:45 PM
doctor mike's Avatar
Lift
I got the same one with the same wheel chock.I use a black widow sissor lift to raise the bike to get the wheels of the lift.what I have trouble with is getting the bike out of the wheel chock when trying to get off the lift.any ideas?
BBP ULTRA,14" FACTORY 47 BARS,DAY MAKERS,MEAN MUG,JACKPOT 2-1-2,V&H MONSTER OVALS,WOODS 222 CAMS,MACH2 AC,POWER VISION,500 WATT J&M ROKKER 6 SPEAKERS,AGITATOR RIMS
doctor mike is offline
post #10 of 19 (permalink) Old 10-08-2013, 11:06 PM
Triplej's Avatar
You need a jack to raise it off the lift. Here is one of many. http://www.discountramps.com/motorcycle-lift-jack.htm
Triplej is offline
harbor freight lift table on sale AzHogRider Aftermarket Accessories 24 06-12-2017 05:55 PM
Good deal on lift table harbor freight ChivoChavez321 Aftermarket Accessories 51 12-07-2014 08:16 AM
How do you tie down to Harbor Freight Lift? Deano *General Road Glide Discussions/Pictures 31 05-02-2014 05:12 PM
Harbor Freight Lift Table Coupon skratch *General Road Glide Discussions/Pictures 14 06-01-2012 09:42 AM
Harbor Freight 1k lift SMSgt B *General Road Glide Discussions/Pictures 9 10-30-2011 12:09 PM
