Stupid question - Installing lifters - Road Glide Forums
post #1 of 5 (permalink) Old 10-30-2013, 10:33 PM Thread Starter
r0de_runr's Avatar
Ok, so I'm gonna put in a different cam. 2013 FLTRU.
Use the magnetic holder to keep the lifter from falling into the cam chest.
But if I want to replace the lifters while I'm there, after the cam is out, can I drop the lifters into my hand and replace with new ones being careful of the anti-rotating key?
I've done lifters before by removing the lifter blocks.
Just trying to save a step and that's two more gaskets and 8 more bolts not to have to torque.
Greg
r0de_runr is offline
post #2 of 5 (permalink) Old 10-30-2013, 11:50 PM
torqu's Avatar
Why would you not just change the gaskets while your right there?
torqu is offline
post #3 of 5 (permalink) Old 10-30-2013, 11:56 PM
tdkkart's Avatar
If you've got a gasket that's sealed, why mess with it??
At least 4 of those 8 bolts like to be a pain in the ass to take out and put back in.
I see no reason whay you couldn't change lifters that way, might want to do one at a time just to make double sure the anti-rotation pin doesn't try to give you fits.
tdkkart is offline
post #4 of 5 (permalink) Old 10-31-2013, 09:01 PM Thread Starter
r0de_runr's Avatar
No you can't. The outside lifters fall out, but the inside two hit the crank breaking boss, so the lifter blocks must be removed to replace lifters.
post #5 of 5 (permalink) Old 10-31-2013, 10:43 PM
tdkkart's Avatar
DOH!!! Oh well, worth a shot.........
tdkkart is offline
Installing new lifters question Diverrick Engine Related 21 03-09-2016 08:45 PM
Stupid is as stupid does: Brukus locks loosen NORSEMAN *General Road Glide Discussions/Pictures 45 04-12-2015 04:59 PM
My Stupid QUESTION...... Nevadasun *General Road Glide Discussions/Pictures 7 09-27-2011 11:43 PM
Primary Oil stupid question jimmyray11349 *General Road Glide Discussions/Pictures 1 09-27-2011 09:19 PM
A Stupid/Ignorant Question-- Gasoline Fumes BDMastiff *General Road Glide Discussions/Pictures 30 06-08-2011 08:13 AM
