Buky Malo install problems! Love the bars! Just a FYI on the install! - Road Glide Forums
post #1 of 15 (permalink) Old 04-07-2014, 11:12 AM Thread Starter
bigshaqa's Avatar
Well here it goes. 2008 Road Glide ABS
I decided after reading all the post and good info on installing ape hangers on the shark I come to the conclusion to forget the $800-$1000 price on the install and do it with the help of a friend! Well everything went fine with the install until we got to the wiring! OMG! Advice rite here and now if your heavy handed like I am be very careful at this point! This what happened. We took the wires off the stock bars and headed to the stealership to let them the take the green plug off the dreaded TBW and hardwire it. Got there and they said that is what they do when they wire the TBW is just hard wire it! I felt confident in what he said and at the work they did on the TBW! Headed back the the bike and we started pulling the wire through the new bars. We got almost to the end and the TBW got bunched up on the last bend with the shrink wrap, so my smart friend said out would be fine cause it has only got to go another inch before it is seated in the bars. He started forcing it in with a few hand taps and sure enough it fell in place! We put the bars on and tighten them down and started the bike to see if everything was working properly! You guessed it NO THROTTLE! Pulled the TBW back out and hooked it up to the connector outside the bars and cranked up twisted the throttle VROOM VROOM ok all fine and dandy! We figured when we forced the TBW in the bars and wires were bunched up as a result it effected the throttle! Back in we go with the wires, hook up again no throttle! CRAP! All we can think of now is the hard wiring the stealership did was weak when it got in the bars and in a bind! Off to the stealership we go again! They looked them over and said everything looks fine but were gonna resoder and tighten up the shrink wrap! Took the resodered TBW back shoot them through the bars (by this time we are professionals at this lol) hook up no throttle! Advice when you hook up all the wiring and connectors and the engine light comes on when you try and crank it you probably gonna have an issue. To make a long story short what happened was we were probably waaaaayyyyy to mean to that TBW! We did not realize how sensitive it was! Handle with caution! A lot of people also say to cut the green plug off and hardwire it but my advice would be to just spend the $100 and get the CVO TBW or twist grip throttle! It comes without the little green connector and it is also a longer wire! I did not have to extend it either. Once we got back to wire the CVO TBW and cleared all the codes before we cranked her up no engine light EUREKA!!!! With the 14" Malos I did not have to extend the wires at all as long as you get the CVO twist grip throttle which is interchangeable! For the cables I went +6 but should've went +6 clutch +4 on the upper brake line! In my opinion when you run the wires go with the TBW wire first then do the other wires oh and Vaseline is a blessing while doin it. I'll post pics later! Good thing is I learned a lot about my bike I think that was a lesson well learned.
bigshaqa is offline
post #2 of 15 (permalink) Old 04-07-2014, 12:22 PM
sdlakerfan79's Avatar
the subject line makes it seem as if it was a problem with the Buky Bars. Not necessarily misleading, but a bit confusing. #justsayin'
sdlakerfan79 is offline
post #3 of 15 (permalink) Old 04-07-2014, 01:37 PM Thread Starter
bigshaqa's Avatar
I say install problems but I can see where you come to that conclusion so I'll change it! I love my freaking bars by the way lol!
bigshaqa is offline
post #4 of 15 (permalink) Old 04-07-2014, 01:39 PM Thread Starter
bigshaqa's Avatar
How's that? SDlakerfan?
bigshaqa is offline
post #5 of 15 (permalink) Old 04-07-2014, 03:15 PM
Originally Posted by bigshaqa View Post
To make a long story short......
too late
Built, not bought. 2007 FLHP. Raked, stretched, 107 motor, Road Glide conversion. Garage built bike
jetlag is offline
post #6 of 15 (permalink) Old 04-07-2014, 03:52 PM
RebelGlide's Avatar
looks good!!
2013 Road Glide Custom..Big Blue Pearl
D&D fat cat, Stage 1 AC, HD Tuner, So Cal HID, 12" Malo's, 8" KW and 12" WV, and other doodads.
RebelGlide is offline
post #7 of 15 (permalink) Old 04-07-2014, 06:24 PM
The Buky people are always at the Long Beach Swapmeet I was going to go with PY MonkeyBars But now im thinking Buky Bars !!!!!!!!!!!!!!!!
johnnynitro is offline
post #8 of 15 (permalink) Old 04-08-2014, 05:02 AM Thread Starter
bigshaqa's Avatar
Johnnynitro I can say this about the Malos I have! I went in and out of those bars 3 times with the wires and not one time did they come back frayed or cut! Every time I had to pull then back out they were nice and clean. No burrs whatsoever! I was gonna go with Yaffe's myself!
bigshaqa is offline
post #9 of 15 (permalink) Old 04-08-2014, 05:04 AM Thread Starter
bigshaqa's Avatar
Jetlag your rite that was long lol! Sorry just trying to help someone out!
bigshaqa is offline
post #10 of 15 (permalink) Old 04-08-2014, 05:16 AM
Harleyagain's Avatar
I enjoyed your story and the outcome!
Bob
Harleyagain is offline
14" Buky Bars - Malo sdlakerfan79 *General Road Glide Discussions/Pictures 50 11-25-2016 07:24 PM
16" Malo Buky Bars payner Controls & Handlebars 15 08-17-2015 09:56 PM
14" Buky Malo install! With problems! bigshaqa Fluids and Lubricants 0 04-07-2014 09:06 AM
14 in Buky Malo bars on RG with ABS bigshaqa *General Road Glide Discussions/Pictures 26 03-19-2014 04:06 PM
12'' Buky Malo Bars - BLACK! HD2012CVO Controls & Handlebars 8 03-13-2014 04:26 PM
