I'm interested in putting together a "basics" RG garage setup in my 2 car garage - where the bike will now go inside and the MINI parks out in the cold - so what do I need, i.e. battery tender, basic tools, jack, lift, etc??? Let me know...
Not in all cases. HD is good at coming up with expensive specialty tools (their ignition switch alignment tool) that can be replaced by something simple you probably already have (a screwdriver). That's where these forums come in really handy.Then when you start using the First one, begin buying everything is says you need!
In the summer - a fan
I am fortunate to have a large garage. I can angle park three bikes beside the car on my side of the garage. But if I need to work on one I can use my Big Blue lift and still keep the MINI warm and comfortable at night. If all three are on the side I can pull the MINI far enough forward that I can get two of them in and out without moving the car. Life is good.... where the bike will now go inside and the MINI parks out in the cold ...
