Hello Everyone
I've just joined this site and bought my first Road Glide.
I live in TX and requires a state inspection sticker.
and was looking for ideas for locations suggestions
Thanks
Welcome to the Tank from North Texas. What part of Texas are you from?
On my RGU I put my inspection sticker on the plate that attached to the bottom of the license plate holder which is tucked under the Tour Pak and is pretty well hidden. Without a Tour Pak I would opt for somewhere else.
Here is a chrome plate made for inspection stickers that I had on the Heritage and you can find lots of places to mount it inconspicuously. Can pick them up at most dealerships and Indy's.
I bought the plate that bolts behind the license plate and bent the sticker part up to about 105 degrees so it didnt hit the tail light.. It is hard to see it untill you get right up on it..
They are required here in WV but it is up in the air on where to put them. Some put them on the inside of the saddlebag lid. But I think that just gives the law a reason to pull you over. Some put them on the fork tube which, in my opinion is an ugly place to put it. I have mine on a chrome tag mounted to the front of the frame on the cross member. I like the tag mounted next to the plate option too!
In NY either on the downtube or front fork lower. Harley dealers almost always on the downtube. NY does not allow those plates unless they are permanently afixed by welding but I never heard of anyone getting a ticket for using a bolt on.
Being from Texas also, I just put mine in the right saddlebag...the law says it must be presented if asked by law enforcement. Now, that may or may not be an easy pullover reason but as small as the sticker is on the plate it would be hard to see at a glance anyways by the officer.
I took the bolt off of the kickstand and placed the chrome tag holder there and replaced the bolt. It is required in Pa to be on the left side of the bike and the holder to be UNREMOVEABLE but when getting inspected that isn't enforced they just stick it on there.
steelhead
Related Threads
Road Glide
1.4M posts
49.1K members
Since 2009
