Can someone plz tell me the correct size of my rear non ABS caliper bleeder screw? i want to replace with a speed bleeder. I called my HD Dealer and they did not know. Go figure. Thx
There are only a few sizes for bleeder screws so go to the local ACE HARDWARE store and get one there. Pull the old bleeder screw out and take it with you.
Did you try using the Mighty Vac Brake bleeder? The Mighty Vac is available at most auto part stores and it is the best way to bleed the brakes on the bike. You can gravity bleed the front brakes just by taking the front brake reservoir cover off and then opening the bleeder screws making sure to JUST DO 1 caliper at a time, make sure that you don't run the reservoir out of brake fluid.
I bled the front brakes and they feel just right. The rear is too soft. I might try the Mighty Vac you suggested, i heard that it works well. I just thiught a speed bleeder would be faster. Had no idea one would be so hard to find. Thx for the suggestion.
Related Threads
Road Glide
1.4M posts
49.1K members
Since 2009
