Tank lift kit.
Go to a hardware store and buy 2- 3/8 X ? U bolts, 2-5/8 X 1 1/4 hex hd bolts, 2 -5/8 lock washers and 2- 5/8 flat washers and you have your lift kit.
Use the flat bar from the U bolt to lift your tank, (they come in various lengths). You might want to paint it black prior to installation.
Good luck.
Tank lift kit.
Good luck.
DK front 1.5” and rear 1”. Definitely helps head temps with the air having more room to pass through and not get heat soaked as much with stock tank position. 10 degree drop when I hit it with the thermo gun
Related Threads
Road Glide
1.4M posts
49.1K members
Since 2009
