Gauge issues....what does your bike do? - Road Glide Forums
post #1 of 2 (permalink) Old 05-10-2015, 03:11 PM Thread Starter
2010 FLTRX's Avatar
I have two odd factory gauge issues.
The first, is that my voltmeter doesn't "shut off" when the bike is off. It still shows battery voltage, and from what I understand it should shut off with the ignition. The concern with this, is that I've had to replace my main battery about every two years since new, and I'm wondering if this full time draw is why.
The second issue, is that my air temp gauge is reading way too high. When I shut the bike off, it also doesn't seem to turn off fully. It's only dropping to 40 degrees, and then when I turn the bike on it jumps to about 110 (which is the matching "change" compared to air temp outside). It's acting as if it's zeroing at 40 degrees.
Now of course you don't really pay attention to this stuff till something is wrong....so I'm not sure now if both of those gauges were supposed to drop to zero with the bike off. My volt gauge has always stayed on, the temp gauge just started this (I know, I know, nobody likes them anyway).
Just curious to hear what other people's bikes do when the ignition is turned off, and any other thoughts.
Sal - 2010 Vivid Black FLTRX
2010 FLTRX is offline
post #2 of 2 (permalink) Old 05-10-2015, 03:21 PM
Not to be a dick but get rid of the air temp gauge and put something useful like the oil temp in its place. the voltage gauge on mine drops when off. You can check it for draws to make sure but you may just have a bad gauge
Tire pressure gauge & tire depth gauge cobra206 Miscellaneous for Sale 1 12-04-2016 10:37 AM
Oil temp gauge wanted (gauge only, not full kit" SickRick Wanted! (Buy or Trade) 0 04-08-2013 02:54 PM
Nice touch! Does your dealer do this? Govdog76 General Off-Topic Discussions 76 01-13-2013 09:08 AM
Does your bike "feel' heavy? rmcdonald *General Road Glide Discussions/Pictures 32 08-28-2012 07:49 PM
Do your your bike out side ? irharley *General Road Glide Discussions/Pictures 88 02-27-2012 12:14 PM
