Hydraulic clutch lever friction zone fix update! - Road Glide Forums
 56Likes
post #1 of 83 (permalink) Old 10-23-2018, 10:35 PM Thread Starter
BigBlockBobby's Avatar
Here is a "how to" I made for the friction zone fix. Thanks to crazy4ink for letting me know about this part.
This mod reduces the reach of the clutch lever before it enters the friction zone. Not the total throw itself, but as you release the clutch lever it starts to grab earlier (closer to the grip). It will grab around the mid point instead of the very end of the lever throw.
If feels more natural to me especially in low speed parking lot maneuvers and technical riding.
Hope this helps anyone looking for a fix and best thing is that it uses a factory part that is now being installed on the 2019 models. [IMG][/IMG]
BigBlockBobby is offline
post #2 of 83 (permalink) Old 10-23-2018, 10:36 PM Thread Starter
You will need to pick up Part #37000295 was $10.08 from New Castle HD. Primary gasket PN# 25700378 is around $25.00-29.00 from most dealers and then 1 quart of Mobil-1 20w50 V twin oil (or whatever oil you use) for the primary is about $9.54 from Walmart. You will also need a primary drain plug o-ring if you don't re use the factory o ring for around $2.00 at most dealers. I reused my derby cover rubber o-ring.
post #3 of 83 (permalink) Old 10-23-2018, 10:37 PM Thread Starter
Remove drain plug. While it is draining move on to removing the shift lever,floorboard, and floorboard bracket. [IMG] aluminum conduct electricity[/IMG]
post #4 of 83 (permalink) Old 10-23-2018, 10:39 PM Thread Starter
Remove floorboard.[IMG][/IMG]
post #5 of 83 (permalink) Old 10-23-2018, 10:40 PM Thread Starter
Remove floorboard bracket. [IMG][/IMG]
post #6 of 83 (permalink) Old 10-23-2018, 10:41 PM Thread Starter
Re install drain plug. [IMG][/IMG]
post #7 of 83 (permalink) Old 10-23-2018, 10:43 PM Thread Starter
Remove primary cover. [IMG][/IMG]
post #8 of 83 (permalink) Old 10-23-2018, 10:44 PM Thread Starter
Remove clutch pressure plate spring bolts. [IMG][/IMG]
post #9 of 83 (permalink) Old 10-23-2018, 10:46 PM Thread Starter
Remove springs. [IMG][/IMG]
post #10 of 83 (permalink) Old 10-23-2018, 10:48 PM Thread Starter
Remove clutch pressure plate and clutch friction/steel plates making sure to keep them in order. [IMG][/IMG]
2019 Friction Zone Fix? KansasFLTRU *General Road Glide Discussions/Pictures 39 10-12-2018 10:54 AM
Friction plate thickness Redfish Joe Engine Related 2 02-27-2018 03:15 PM
Lever Change Kuryakyn Boss Lever 16RGS *General Road Glide Discussions/Pictures 9 03-31-2017 09:45 AM
Fix it or 2015? FIX! 08Zinc Engine Related 24 02-14-2017 06:26 PM
New pipes w/ hydraulic clutch? Pokerstar Intake and Exhaust 0 12-25-2010 10:25 PM
