Garage Chock - Page 4 - Road Glide Forums
 14Likes
post #31 of 40 (permalink) Old 01-28-2019, 05:40 PM
RGKen's Avatar
Originally Posted by Ironhorse View Post
I have used my Condor, not anchored to the floor, for two bikes over five years, a Heritage Classic and my Road Glide and never have had any problem.
I did call Condor and asked if they knew of any reason why a bike would just fall over on its own and they said that if the front tire was to loose air pressure and not be tight in the cradle the bike could lean one way or another and eventually fall.
This makes sense. I have a feeling something is missing from the story IMO
Nah, you can believe what you want and use your Condor however you want. It really doesn't matter to me.
In the end, if it were me and I was going to use a Condor to keep my bike in over the winter, or for long periods of time, I would most definitely anchor it even more now knowing that something as simple as an under inflated tire could cause it to move and possibly fall over.
I really don't get why it's such a big deal that I suggested you consider making something more secure. To each his own I guess....
2018 FLTRXS
RGKen is offline
post #32 of 40 (permalink) Old 01-28-2019, 06:00 PM
Ironhorse's Avatar
Itís not a big deal to me. I was just passing along some info I thought would be hepful.
RGKen likes this.
Ironhorse 2015 RGS Vivid Black
Ironhorse is offline
post #33 of 40 (permalink) Old 01-28-2019, 06:31 PM
I have a Condor wheel chock and it works good but I find it can be a real pain to pull the bike back out of.
I have used it for years and never once thought it was not secure enough
Ironhorse likes this.
2010 RG Custom
209 Crossbones
Canuck is offline
post #34 of 40 (permalink) Old 01-28-2019, 06:38 PM
2010 RG Custom
209 Crossbones
Canuck is offline
post #35 of 40 (permalink) Old 01-29-2019, 08:28 AM
RGKen's Avatar
Me too....
2018 FLTRXS
RGKen is offline
post #36 of 40 (permalink) Old 01-29-2019, 10:14 AM
I would be skeptical of a bike docked in the Condor just falling over as well, I have had both my RG and SG docked in the condor chalk in the garage and neither have ever fallen over. The only way I could fathom this happening is that the cradle for the wheel is not adjusted for the correct size wheel.
Life is not a journey to the grave with the intention of arriving safely in
a pretty and well-preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out, and loudly proclaiming --WOW -- " What a ride!!!
HD-RG-SD is offline
post #37 of 40 (permalink) Old 01-30-2019, 02:03 PM
Pike1989's Avatar
I've not got anything fancy and after seeing the tip overs you guys got me a little nervous lol. I used a couple 2x6s, a one inch strip, and some black pipe to make a little "lift/stand". Pretty much to keep weight off tires and it helps for little things when I need the bike to be level. I've used it for 4 years now with no issues. I cant take credit for it, it's not the spawn of my mind. I found the plans lurking on another forum.
(Dont mind the clutter) pics aren't great but they show it in action.
Pike1989 is offline
post #38 of 40 (permalink) Old 01-30-2019, 05:13 PM
RGKen's Avatar
That's just a homemade version of what shops used to use 20yrs ago. Worked great for at the time for what it was but more that one guy got smacked real hard from that bar if the bike moved.
2018 FLTRXS
RGKen is offline
post #39 of 40 (permalink) Old 01-30-2019, 06:16 PM
Love my Condor
Have it mounted to my lift (Horrible Freight). I always just ride in, up and get off. I tie it down to the lift because I leave it there. Also have the HF version but I find that the tire is hard to fit properly and often gets stuck (need to pry it out). Never happens on the Condor. Really nice product.
BigRic is offline
post #40 of 40 (permalink) Old 02-13-2019, 09:54 PM
Hopalong48's Avatar
I would prolly trip over the sumbitch
Sent from my SAMSUNG-SM-G891A using Tapatalk
RGKen likes this.
Hopalong48 is offline
Harbor Freight Wheel Chock/ BAD mouser58 *General Road Glide Discussions/Pictures 19 03-06-2017 12:27 PM
HD remote garage door opener antenna modification madsonp *General Road Glide Discussions/Pictures 9 12-07-2015 09:13 PM
Garage Door Opener for $11.62 dklanecky Do-IT-Yourself 108 04-29-2015 03:55 PM
Ideas for garage storage for accessories McGruder Aftermarket Accessories 20 10-18-2014 03:49 PM
Garage Door Opener/ECM Upload Qwicker ECM/Fuel Management systems 8 02-05-2014 08:33 PM
