Performance changes after removal of M8 Catalytic Converter - Road Glide Forums
 6Likes
post #1 of 11 (permalink) Old 02-13-2019, 10:45 AM Thread Starter
paid4c4's Avatar
I have a 2017 RGU with Stage II Torque Cam and am thinking of removing my catalytic converter. I just wondering what experience others have had after removal. Performance? Sound?
Thank You;
Bill
2017 Road Glide Ultra, Black Hills Gold and Quartz Black, purchased Jan 6th, 2018
2012 Goldwing California Side Car Trike Ky Wildcat Blue, for when Kathy wants to ride.
2013 Ultra Limited, Rear ended and totaled while riding Jelico Mountain, 06-09-17, RIP.
paid4c4 is offline
post #2 of 11 (permalink) Old 02-13-2019, 10:56 AM
Just sound
rdc401 is offline
post #3 of 11 (permalink) Old 02-13-2019, 11:41 AM
Glide08's Avatar
Mainly less heat performance difference is nil
Glide08 is offline
post #4 of 11 (permalink) Old 02-14-2019, 11:22 PM
Hammerhandle's Avatar
Just seen another member comment that when they tested it with the cat removed, the only thing that flows better is a D&D.
2019 FLTRXS Wicked Red Denim
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants"
Hammerhandle is offline
post #5 of 11 (permalink) Old 02-15-2019, 09:53 PM
Desertwndrr's Avatar
The M8 cat has been shown to flow exceptionally well and there is virtually no performance gain between an aftermarket header and the stock header with cat. The gain is in the level of sound produced and a reduction of heat. If you want more sound or reduced heat, gut the cat. Save your coin and avoid buying an aftermarket header. You can gut the cat on the bike through the enlarged rear right side opening without cutting a window and rewelding.
Glide08 and paid4c4 like this.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #6 of 11 (permalink) Old 02-15-2019, 10:36 PM
Banned
You already have stage 2 so probably nothing in performance but your passenger will thank you.
paid4c4 likes this.
post #7 of 11 (permalink) Old 02-16-2019, 08:13 AM
On an otherwise stock ‘19 114:
Gutted mine mainly to reduce heat... it worked beautifully.
This is very subjective, but it did end up a “bit” louder to my ears, however G/F says it’s no different......
It did drastically improve off idle response, mainly when 2 up, with no adverse effects any where else.
'19 Road Glide Ultra
'13 BMW K1600
'09 Ultra Classic
mykaos is offline
post #8 of 11 (permalink) Old 02-17-2019, 05:46 AM
Painey01's Avatar
Looking to do this, how did you remove the cat through the opening without cutting a window?
2019 ROAD GLIDE SPECIAL : Candy Hot Rod Red Flake, Stage 2, 14" KST Renegade bars, Custom Dynamics turn signals, Klockwerks screen, Cobra Neighbor Hater slip-ons, Diamond Audio amp, Hertz speakers, adventblack chopped tour pac, red alligator seat and backrest
Painey01 is offline
post #9 of 11 (permalink) Old 02-17-2019, 08:25 AM
The outlet on the right side is large enough. Use a long drill bit and drill through around the cat material. You can then break it up and pull out the rear of the header.
Painey01 likes this.
post #10 of 11 (permalink) Old 02-17-2019, 11:28 AM Thread Starter
paid4c4's Avatar
After researching cat removal on M8's I am going to use a 15/8 inch deep metal hole saw on a mandrel, and a 1.5 inch paddle bit to get the sides. A magnet and vac to clean out the mess. I'll block off the cross over pipe to keep out the debris. A friend of mine got about half way through drilling his cat out and the whole cat became detached from the pipe. He broke it up and removed it with the pipe being clean other than some type of mastic. I'm thinking I'll either video the process when I do it or at least a lot of photos.
Bill
paid4c4 is offline
2017-2018 RGS Where is the Catalytic Converter? RoadWolf1172 Intake and Exhaust 9 12-31-2017 12:36 PM
Catalytic converter removal bfore Intake and Exhaust 12 09-22-2016 06:09 AM
2016 CVO Road Glide Catalytic Converter? f18spanky Intake and Exhaust 6 07-04-2016 06:48 PM
Catalytic removal - Warranty void? Cashectomy Intake and Exhaust 18 12-16-2014 12:58 PM
Performance shop list FLTR2008Trike Engine Related 6 12-29-2012 11:14 AM
