Trans oil transfer kit from the MoCo - Page 16 - Road Glide Forums
 178Likes
post #151 of 211 (permalink) Old 06-20-2019, 10:17 PM
BigBlockBobby's Avatar
Last week I installed the primary vent kit myself on my 2018 RGS and my Wife's 2018 SGS.
I will let you all know how it does for both of them in 500 mile intervals.
BigBlockBobby is offline
post #152 of 211 (permalink) Old 06-21-2019, 05:12 AM
How was it to install. Did you have to remove the inner primary?
ROCK FISH is offline
post #153 of 211 (permalink) Old 06-22-2019, 11:41 AM
geo8866's Avatar
I was wondering the same thing. I'm trying to figure out if it is something I can handle or if I should pay the thieves to do it for me.
If anyone who has done this or had it done can post a few pictures, that would be helpful.
geo8866 is offline
post #154 of 211 (permalink) Old 06-22-2019, 12:10 PM
madmat's Avatar
More details and pics if you have them, TY Bobby!
18 RGS Bonneville Salt Pearl
madmat is offline
post #155 of 211 (permalink) Old 06-22-2019, 04:01 PM
Sorry no pics as I was in a hurry when I did the bikes. Had a ride the following morning and was getting them done around 11:30 pm the night before. I can give a few tips and helpful info though.
1)The template Harley includes you have to cut out yourself. It is very thin paper. I would suggest after you make it transfer or copy it over to a small scrap of thin flat plastic if you are going to be doing a few of these. I have one I made just for doing these in the future.
2) This is really a very easy job to do. The aluminum for the inner primary is fairly soft and very easy to cut through with a couple of sharp drill bits. I made my pilot hole with a 1/4 inch bit and then stepped up to the final size. My final thought on this is use a good (sharp) drill bit. It will make the hole nice and clean.
3) I didn't have any problems with metal chips getting into anything. I covered up the clutch basket with a old plastic bag, then I taped a blue shop rag under the area I was drilling through to catch anything that could have fallen into the primary as well. A slow cutting speed on the drill will keep from throwing chips everywhere.
4) The vent tube I pulled through using some long needle nose pliers.
5) After you get everything back together and torqued to spec I used some compressed air and cleaned off the back of the primary. You don't want any metal shavings getting onto the drive belt etc.
madmat, Little Wing, RGBav and 2 others like this.
post #156 of 211 (permalink) Old 06-22-2019, 04:23 PM
RGKen's Avatar
So both your bikes had the fluid migration issue? How many miles on the bikes?
2018 FLTRXS
RGKen is online now
post #157 of 211 (permalink) Old 06-22-2019, 04:54 PM
madmat's Avatar
TY! Great detail Bobby
madmat is offline
post #158 of 211 (permalink) Old 06-23-2019, 11:31 PM
Yes, both bikes had the fluid migration issue. I checked the fluids on both of the bikes when brand new before the 2 hour ride home from the dealer. I noticed it on both bikes at the 1K service. I do all my own work to our bikes so I started checking it before every ride.
I now have 9k on my bike and the wife has around 4k. Every thousand miles both bikes would transfer between 4-6 fluid ounces.
I'm happy to say that with the primary vent kits installed 500 miles on my bike and 350 miles on the wife's bike the trans fluid is at exactly the same spot on the stick! I will keep updating in 500 mile intervals.
Marc-Andre Carrier likes this.
post #159 of 211 (permalink) Old 06-24-2019, 07:44 AM
Emil1's Avatar
I have 40k miles on my 2017 RGU and no extended warranty. I talked my the service folks at my dealership. They recommended that I call Harley customer service - which I did. Customer service provided a case number - which I gave to the dealership. The dealership and customer service worked together and repaired my bike at no cost.
I've ridden 1,000 since then and it seems to have worked.
BigBlockBobby likes this.
Emil1 is offline
post #160 of 211 (permalink) Old 06-24-2019, 10:02 AM
Vent seems to be working
Three weeks ago i picked up a new 2019 Road Glide S. I first discovered the transmission fluid was low at 800 miles. Stopped at the dealeer so they could add and document the amount. At 1100 my dealer put in the vent and it has been steady for 250 miles. I hope it did the trick
Rupp80 is offline
Can the RG.org staff req an interview with MoCo Lu *General Road Glide Discussions/Pictures 10 09-02-2017 11:10 PM
M-8 trans leak bigal51 Fluids and Lubricants 5 06-25-2017 01:35 PM
2013 Road Glide trans dipstick 89FXRS Fluids and Lubricants 4 09-08-2016 09:38 PM
Trans oil really, really hot! August Fluids and Lubricants 6 09-12-2014 04:44 PM
