Trans oil transfer kit from the MoCo - Page 2 - Road Glide Forums
 117Likes
post #11 of 147 (permalink) Old 04-13-2019, 09:28 AM Thread Starter
Thermodyne's Avatar
Originally Posted by Dragon Dude View Post
I wonder if a crank vent from ET performance would relieve the crank case pressure enough to stop the oil transfer, if the crank case pressure is the cause.
That setup is mickey mouse. Just a rehash of the old top breather gizmos.
The top of the trans already has a passage down to the oil pan. Air cooled motors return oil through a tube installed there, and its just capped on wet heads.
If you want to vent the pan, then modifying one of the return tubes would be the way to go about it. Wet heads would just need a separation baffle and a hose added to a tube. Air heads would need a second tube to be added as the vent. The vent could run in through the side of the return tube.
Thermodyne is offline
post #12 of 147 (permalink) Old 04-13-2019, 11:49 AM
18 Wicked Special's Avatar
Originally Posted by Thermodyne View Post
XMSN = Transmission?
The crank case vents through the vent valves into the breather.
The primary vents through the mainshaft to the trans, and the trans vents through the vent hose in the top cover.
Only difference on the M8 is the new vent valves. But its the same flapper valve in a package with a lot more oil control.
After thinking on it a while, I'm ready to dig out my old vacuum gauge and see if the is any sucking taking place on the trans. Because with out some sort of lower pressure in the primary pulling the fluid across, this kit is for naught. Just like the first fix, which was lefty seals in the motor.
Sorry about that, work abbreviation, yes-transmission=xmsn. Appreciate the info and cut-away pic. Wonder if tolerances come into play with some not having the transfer issue yet. Any chance pressure is building on the right side of the clutch pushrod, causing transfer? You thinking of hooking a vacuum gauge to the transmission vent tube and seeing what going on during cruise and aggressive acceleration/deceleration?
I'm planning on using Mobil 1 75w90 or 75w140 gear oil in my transmission as I have in prior bikes on the next change( Dealer used Syn3 in all 3 holes at the included 1000mi service). I've noticed smoother/quieter shifting with it. Not sure if it will make a difference as far as the transfer issue though. Only have 1800 mi. on my RGS so far and no problems.
18 Wicked Special is offline
post #13 of 147 (permalink) Old 04-13-2019, 11:55 AM
Little Wing's Avatar
because of Kevin Cameron's article about the "new" Milwaukee-8 i was under the impression that overfills were directed to the transmission.
"Small details are important. In the past, if the oil was overfilled, excess oil could wet the air filter via the breather. This has now been rerouted through the transmission case."
https://www.cycleworld.com/harley-da...engine#page-10
can't vouch for the validity of that statement, but for the sake of discussion, could an "overfill" situation pressurize the tranny, leading to the primary?
Also, if they vent to atmosphere, wouldn't that be "illegal" in Europa?
@Thermodyne do you have migration on your '18 RGU?
i just drained & filled mine and it was ok.
'18 FLTRX • '04 BAR HOPPER • '94 FLSTCTHE BEST BIKE ...is the one you're on!!!
Little Wing is offline
post #14 of 147 (permalink) Old 04-13-2019, 04:14 PM Thread Starter
Thermodyne's Avatar
No idea as to what the EU allows for on scooters.
Mine has not transferred as of yet. But it really has not had the opportunity, still working on the second thousand miles. Today was the first run on the big slab of more than a few miles. I'll keep Formula+ in the trans for now, just in case.
If you look at the changes that came in 17, you got a new trapdoor with the clutch cylinder sealed to it. So there could be drain issues and there could be pumping issues from the slave piston. On the other end you got a new clutch, and the hub fits closely onto a cylinder shaped area at the end of the main shaft, so there could be some pumping taking place there too. And when one side pushes, the other side would suck. The much larger area in the clutch cavity would make it less apt to pump fluid back to the trans.
When the MoCo first realized there was an issue, they kinda fell back on history. They went right after the lefty seal, which has been an issue in the past. Then they played around some on the trapdoor area, couple of test fixes, and now they are back fooling with suction in the primary. So I'm thinking its one of three things. 1) They have no idea as to the cause. 2) Its a perfect storm sort of thing where there are many issues and when a few of them end up on the same scooter, it transfers. 3) They know what the issue is and are looking for the cheapest fix that can be done in the field. With that in place, they can then quietly effect a redesign on production scooters without fear of getting forced into putting the production fix on scooters in the field. If it was say a redesigned trapdoor, that would cost an arm and a leg to do as a no cost campaign.
Little Wing likes this.
post #15 of 147 (permalink) Old 04-13-2019, 04:16 PM Thread Starter
Thermodyne's Avatar
Yep. Actually going to try and borrow a transducer and hook it up to my meter, then data log the results.
post #16 of 147 (permalink) Old 04-13-2019, 04:51 PM
My '19 RG has the migration issue. I checked the trans fluid level at delivery and at about 200 miles, it was in the middle of the add and full marks. Checked it again on Monday at 631 miles, nothing on the stick. It took 16 ozs to put it in the middle.
I rode 200 miles and checked it the next morning, down another 5 ozs.
So I pulled the derby cover and removed the excess. Then pulled the pushrod and modified it. Just trying the simplest fix first. If that doesn't help, I'll have to see if the MoCo's new vent tube is successful. If not, I'll modify the trans side cover to better drain the oil away from the bearing area.
Dmerch is offline
post #17 of 147 (permalink) Old 04-13-2019, 05:43 PM
thanks for your reply.
i am getting ready to turn over 10K on mine. mostly highway cruising, revs usually 2500-3500 in 6th.
i very rarely get to redline; power falls off so soon it's more enjoyable for me to short-shift and it sounds better, too.
so many upgrades to the ole pushrod v-twin!
we should really be glad they're still around instead of trying to make street rods out of 'em.
and the profitable aftermarket always seems to take up the slack for them anyway.
really looking forward to the results of your experimental testing!!!
post #18 of 147 (permalink) Old 04-14-2019, 06:37 AM
Rays Road Glide's Avatar
So far, so good with Black Betty (wamalam)...!
RMC, 2017 Vivid Black RGS
Rays Road Glide is offline
post #19 of 147 (permalink) Old 04-14-2019, 07:20 AM
chstrahl's Avatar
To the OP- this just showed up and they expect you to do that work to your bike? Are you/have you been working with them or is this random?
I wouldn’t think this should be something your avg joe should be doing in their garage if they aren’t mechanically savvy.
chstrahl is offline
post #20 of 147 (permalink) Old 04-14-2019, 11:08 AM
Lu
Lu's Avatar
OP, thanks for the info.
looks like this Harley kit 94100065 can’t be found when you google it.
So you have to drill to install this vent. I rather not do this, with MoCo’s track record, who know if they even tested this & what the long term effect is.
2011 FLTRU - Traded
2017 FLTRXS - Velocity Red Sunglo - Woooooo!!!
Lu is offline
Can the RG.org staff req an interview with MoCo Lu *General Road Glide Discussions/Pictures 10 09-02-2017 11:10 PM
M-8 trans leak bigal51 Fluids and Lubricants 5 06-25-2017 01:35 PM
2013 Road Glide trans dipstick 89FXRS Fluids and Lubricants 4 09-08-2016 09:38 PM
Trans oil really, really hot! August Fluids and Lubricants 6 09-12-2014 04:44 PM
