ABS failure? - Road Glide Forums
 17Likes
post #1 of 25 (permalink) Old 05-10-2019, 10:46 PM Thread Starter
Hdozzie65's Avatar
ABS failure?
Had my 5k service completed today on my 18 RGU. Over the last couple of hundred miles, I had developed a shudder in the front brake, with the brake lever pulsing and a shake in the bars
They suspect that the ABS has failed and need to check with H-D to determine if this is a known issue. For the time being they have disconnected the ABS and no issues with shudder at all. Any other experiences with this?
Hdozzie65 is offline
post #2 of 25 (permalink) Old 05-11-2019, 12:02 PM
I'd make them give you a loner and deadline your ride until fixed. Then again , if you get into an accident, you'll own that dealership.
HD been having abs problems since they added them.
post #3 of 25 (permalink) Old 05-11-2019, 01:20 PM
twowheeladdict's Avatar
So right now you are riding a bike with the ABS light on?
There really should be no difference in braking with the ABS disabled or enabled because the ABS is only active when you are braking and the system senses a tire slip.
Since you are having an "issue", it doesn't matter if there is a known issue unless you are out of warranty which you wouldn't be.
A competent tech should be diagnosing your problem and fixing it under warranty.
geo8866 and Little Wing like this.
twowheeladdict is offline
post #4 of 25 (permalink) Old 05-11-2019, 02:29 PM
Bruce00's Avatar
A dealership sends you on your way with a ABS brake issue on a warranty covered bike? I agree disabling the ABS module will still leave you with functioning non abs brakes, but sure seems there would be a liability issue with that.
Be curious what a lawyer would say, and not a FaceBook Internet Lawyer.....LMAO
geo8866 likes this.
Bikeless
2015 RoadGlide Special--RIP
Tuned by Jamie @ Fuel Moto w/Rinehart 2>1
Bruce00 is offline
post #5 of 25 (permalink) Old 05-11-2019, 11:08 PM Thread Starter
Hdozzie65's Avatar
The ABS light only flashes when the bikes srarts up, then stops. Fortunately not a lot of riding this weekend due to rain and graduations, mother’s day stuff. I will talk with them on Tuesday ( closed on Monday’s) and see what direction they take. The bike is still under warranty, so it will get repaired... hopefully sooner rather than later.
post #6 of 25 (permalink) Old 05-11-2019, 11:19 PM
B407driver's Avatar
The ABS light is supposed to come on at start up and then it goes off once you get past about 5 MPH. The ABS metering blocks are also the reason most manufacturers recommend changing brake fluid every two years....after a while the gunk in the brake fluid will plug up the orifices in the metering block causing the ABS to malfunction. This is especially important if you use DOT 4 fluid.
geo8866 likes this.
2019 Road Glide / 2018 BMW K1600 GA
B407driver is offline
post #7 of 25 (permalink) Old 05-12-2019, 09:58 AM
S.curtis's Avatar
Hope they fix it soon, I would be hesitant to ride
2019 Road Glide Special, 2008 Sportster
If you can read this Thank a Teacher
If in English Thank a Soldier!
S.curtis is offline
post #8 of 25 (permalink) Old 05-12-2019, 06:33 PM
Yoopermoose's Avatar
A warped rotor would give the same symptoms although disconnecting the ABS would not rectify that.
Little Wing likes this.
Yoopermoose is offline
post #9 of 25 (permalink) Old 05-12-2019, 07:53 PM
BH#103's Avatar
If they disconnected the abs the light would stay on.
twowheeladdict and tylerfj24 like this.
"SLIVER"
BH#103 is offline
post #10 of 25 (permalink) Old 05-12-2019, 11:08 PM Thread Starter
Hdozzie65's Avatar
I thought the same thing, although I am not real familiar with ABS systems. Whatever they did “corrected” the symptoms, but they want the bike back as the work order is not closed.
Transmission Bearing Failure Question Stoic Joker Do-IT-Yourself 20 12-06-2018 12:06 PM
Lost a cam bearing failure in a TC-88 Lots of questions Rusty Engine Related 25 10-07-2018 09:00 PM
Complete Instrument cluster failure scopet563 Tech Area 6 09-07-2016 06:14 PM
Clutch Failure Martin Troubleshooting for Road Glides 7 05-30-2011 09:27 AM
Quick detach mount failure? FLTRI *General Road Glide Discussions/Pictures 14 03-29-2011 07:40 AM
