Tire pressure check - Road Glide Forums
 20Likes
post #1 of 20 (permalink) Old 06-30-2019, 06:46 PM Thread Starter
dsmith's Avatar
Tire pressure check
I bet all of you Grey Beards out there (actually I have a grey beard) have a trick for checking/inflating the rear tire. I have that flexible tube from the Motor Company but I bet there is something else out there. I keep on forgetting to ask around at the Gatherings. My shop is limited and I use a bicycle pump. It is a pain laying on your back and fussing with threading that thing on.
dsmith is offline
post #2 of 20 (permalink) Old 06-30-2019, 06:50 PM
Mike U's Avatar
When I changed my tires I replaced the tire valves with right angle ones.
I know that they make right angle adapters that you could use until the next time you replace your tires and have right angle valves installed.
Hope this helps.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
post #3 of 20 (permalink) Old 06-30-2019, 10:24 PM
skratch's Avatar
whenever i do the tires, i lift the bike on my j&s jack. then i can just spin the tire to wherever i need it, and then screw on the extension. my compressor has a air gauge on it, and a clip on the filler so i just pop it on, fill it, then pop it off.
sounds like a pain, but it really only takes a couple of minutes to jack the bike up and i think once you do that, it makes the process much faster so it could even wash out in the end.
Lets Ride NC likes this.
skratch is offline
post #4 of 20 (permalink) Old 07-01-2019, 12:36 AM
JacktheBagger's Avatar
another 82* valve stem user here ..
JtB
2011 Ultra
JacktheBagger is offline
post #5 of 20 (permalink) Old 07-01-2019, 01:11 AM
hd4cruzin's Avatar
Hope this helps.
Mike U.
Ditto, When I had my rear tire replaced I had them change the valve stem to a 90* valve stem. Now its easy to check and fill tire.
2012 FLTRX BBP
hd4cruzin is offline
post #6 of 20 (permalink) Old 07-01-2019, 06:25 AM
madmat's Avatar
If you take the rt side saddlebag off you get a lot of access.
18 RGS Bonneville Salt Pearl
madmat is offline
post #7 of 20 (permalink) Old 07-01-2019, 07:33 AM
Stoic Joker's Avatar
I've got a 9' x 20' piece of carpet that the bikes sit on in the garage, so laying on the floor to get to the rear stem isn't that bad.
...And yes, I do feel rather silly vacuuming the garage ... But it works.
Scarlet Red 2010 Road Glide Custom named Trixie - She's a flashy little minx..
Basic black 1981 Tour Glide Classic named Alice - She's a sleeper project.
Stoic Joker is online now
post #8 of 20 (permalink) Old 07-01-2019, 10:58 AM Thread Starter
dsmith's Avatar
I forgot to mention that I run tubed tires on spoked wheels. Complicates things. Thanks for the tip on the saddlebag. I will give it a try.
madmat likes this.
dsmith is offline
post #9 of 20 (permalink) Old 07-01-2019, 11:05 AM
Mike U's Avatar
Here's another option if interested.
Mike U.
madmat and geo8866 like this.
USMC 1975-1977
Semper Fi!
post #10 of 20 (permalink) Old 07-01-2019, 11:24 AM
wevsspot's Avatar
I don't have the 90 angled valve stems, so I'm still pulling the right saddle bag to check and fill. But, for checking the pressure I've got an air shock gauge that I bought back when the 2015 still had the factory air shocks on it. Plenty of range for tire pressure, accurate and it has a 6" long rubber hose with a screw on fitting for attaching to the valve stem on the rim.
Works a treat.
wevsspot is offline
