Extra connection under the Speedometer/Tachometer - Road Glide Forums
  • 1 Post By FDR's RGC
post #1 of 7 (permalink) Old 07-08-2019, 09:10 PM Thread Starter
Thegreencantina's Avatar
Question Extra connection under the Speedometer/Tachometer
Hi All.
So I removed the speedo bezel on my 2012 to install an Iron Aces mount. Of course like an idiot I forgot to take a picture before disconnecting the wire connectors.
I got everything put back together. Luckily, as far as I could tell, all of the connectors would only fit into one specific connector and none would fit into more than one.
When I got everything connected I was trying to find where to plug one last connector and for the life of me I can't find the female end to plug into.
Is there an extra connector under there for some other purpose that I don't have?
Thanks.
What don't kill you, make you more strong.
Thegreencantina is offline
post #2 of 7 (permalink) Old 07-08-2019, 09:47 PM
FDR's RGC's Avatar
That's for the self destruct button.
hoosierboarder likes this.
FDR's RGC is offline
post #3 of 7 (permalink) Old 07-08-2019, 10:02 PM
BH#103's Avatar
Heated grips
"SLIVER"
BH#103 is offline
post #4 of 7 (permalink) Old 07-08-2019, 10:33 PM
FDR's RGC's Avatar
Originally Posted by BH#103 View Post
Heated grips
black and white wires close to fly by wire twist grip.
post #5 of 7 (permalink) Old 07-08-2019, 10:39 PM Thread Starter
It's no where near the grips. It's literally tied in with the wiring harnesses leading to the speedo and tach.
post #6 of 7 (permalink) Old 07-08-2019, 10:48 PM
Taz_FL's Avatar
yeah, but the wire from the heated grips would run down through the bars , come out the slot in the bars between the handlebar risers and connect there. I'm not posative thats what the wire is for but like the other person, thats what came to mind.
Taz_FL is offline
post #7 of 7 (permalink) Old 07-09-2019, 09:03 PM
Ohiobellboy's Avatar
Post up a pix.
A.K.A OBB
Ohiobellboy is offline
