2015 FLTRUSE CVO Coolant o rings on the head - Road Glide Forums
  • 1 Post By DieselDave
post #1 of 5 (permalink) Old 07-12-2019, 07:20 PM Thread Starter
Anyone with any experience replacing the o ring on the coolant system at the heads? I ve got everything apart but just cant get it all put back together. I can't seem to get the coolant tube to seat down into the adapter on the head far enough to get the little clip back in place to hold the tube down against the o ring. I've attached a pic.... any help would be great. I really don't want to have to put this together and take it to harley. thanks!!
2015 FLTRUSE V&H dresser duals, Hi-Output Mufflers
2002 FLHTCUI 113, V&H true duals, Bassani mufflers, Still have her
mach65 is offline
post #2 of 5 (permalink) Old 07-12-2019, 10:28 PM
DieselDave's Avatar
O ring lubed?
RGKen likes this.
DieselDave is offline
post #3 of 5 (permalink) Old 07-13-2019, 12:37 PM
I have not dealt with this before but have had problems with clearance fit type O rings which seal by resistance. Try lubing with something that is compatible with the O ring. Then heat the area to make the ring soft and pliable.
2016 Road Glide Ultra
dreeves is offline
post #4 of 5 (permalink) Old 07-13-2019, 07:17 PM Thread Starter
Originally Posted by DieselDave View Post
O ring lubed?
Yep......
mach65 is offline
post #5 of 5 (permalink) Old 07-13-2019, 07:22 PM Thread Starter
Thats a great idea!!! never thought about heating the adapter on the head with the o ring in place.......... will let you know how it goes.. Thanks for the tip, i bet it works!!
mach65 is offline
