Gas cap hard to turn - Road Glide Forums
 6Likes
post #1 of 13 (permalink) Old 09-08-2019, 06:06 PM Thread Starter
I have a 2019 FLTRU. The gas cap is a bear to get off. I do not crank it down when I screw it back on. I turn it until it clicks once. Anybody else have this problem? It seems to be worse when the tank is closer to empty.
kjohn23 is offline
post #2 of 13 (permalink) Old 09-08-2019, 06:17 PM
RFG7680's Avatar
This was an issue in 16. Theres a lip that shouldn't be there I took mine off with a file. Worked great. You may have got one of them.
Bruce00 and eddienelson like this.
RFG7680 is online now
post #3 of 13 (permalink) Old 09-08-2019, 07:13 PM
15's had it too.
RFG7680 likes this.
Buzzy is online now
post #4 of 13 (permalink) Old 09-08-2019, 07:18 PM
My 17 Ultra is hard to get off also.
2017 FLRTU
Various other bikes
TennesseeRoadGlide is offline
post #5 of 13 (permalink) Old 09-08-2019, 07:21 PM
RFG7680's Avatar
Look at the lip before the leading thread. If it's not flat and has a raised ridge just on the very edge. That's the issue. They know about it. Either file it off in a few minutes or go to the dealer. They'll give you a new cap.
post #6 of 13 (permalink) Old 09-08-2019, 07:43 PM
Road-dawgs1's Avatar
Oddly enough, there is a new gas cap for 2020. If all else fails, pick one of the new ones up.
RFG7680 likes this.
2019 FLTRU
Road-dawgs1 is offline
post #7 of 13 (permalink) Old 09-08-2019, 08:42 PM
BubbaBeef's Avatar
Location: Northern Illinois, where the suburbs end and the corn fields begin
There was a recall on these gas caps, should be able to get it replaced.
RFG7680 likes this.
Panic, chaos, disorder, my work is done here.
BubbaBeef is offline
post #8 of 13 (permalink) Old 09-08-2019, 09:11 PM
eddienelson's Avatar
Dude just grind that little lip down. Your basically putting a taper on it to start the threading process. If you dont feel comfortable doing it Ill come over and do it for you.
Bevis likes this.
2016 RG Custom Vivid Black
eddienelson is offline
post #9 of 13 (permalink) Old 09-08-2019, 10:29 PM
Warranty, pretty common in past. Take it in💪💪
2016 Road Glide Ultra
dreeves is offline
post #10 of 13 (permalink) Old 09-09-2019, 05:53 PM
HD replaced the one on my 2016 in the 1st year. It got worse with each fill up. It got stuck so bad one day that I had to borrow pliers from a plumber getting fuel next to me to get it off the tank.
Barely put it back on and went to the nearest dealer and they gave me a new one.
peytonkristen is offline
