Making 2017 - up read Oil Presssuree PSI vs Just OK - Road Glide Forums
post #1 of 7 (permalink) Old 11-10-2019, 11:06 AM Thread Starter
Heavy Metal's Avatar
I was told someone know how to get a 2017, 2018 and so on to read on the info Oil Pressure PSI vs just seeing OK on the read out.
Heavy Metal is offline
post #2 of 7 (permalink) Old 11-10-2019, 01:15 PM
craigffb's Avatar
That would be cool.
craigffb is online now
post #3 of 7 (permalink) Old 11-10-2019, 01:57 PM
BB Bomber's Avatar
I don't know that you can. I remember hear lots of griping about that when MoCo made the change.
BB Bomber is offline
post #4 of 7 (permalink) Old 11-12-2019, 08:36 AM
Trendkill's Avatar
As I understand it, the initial readout was the actual PSI, which resulted in an influx of owners in the service department who thought their oil pressure was "low". Changing it to a good/bad readout was the adjustment. I've not heard of anyone being able to switch it back.
2018 Road Glide Special in Bonneville Salt Pearl - Stage II Power, SVT Boneshaker exhaust
Trendkill is online now
post #5 of 7 (permalink) Old 11-12-2019, 08:37 PM
It would read lower at idle as it should. I have been "told" the only way to do it would be with a replacement sensor installed in the engine. I hope that is not correct as it should read the psi.
2017 FLRTU
Various other bikes
TennesseeRoadGlide is offline
post #6 of 7 (permalink) Old 11-13-2019, 08:34 AM
Well interestingly, one of the actual GTS manuals for '19 has the actual oil pressure reading indicated in the diagram instead of "OK". However in subsequent versions of the manual online, it just shows "OK" in that same diagram.
I talked with HD and was told that there will be a sensor kit coming out - but I havent seen nor heard anything more. I havent had the time to call HD and ask again, so if someone is inclined, let us all know
I am not concerned so much with what the oil pressure reading 'normally' indicates - ie: if it is 37, 31, 28, 25 psi or whatever at a given RPM, but I do care about any significant change from what it normally should be. Thats what I want to monitor. I added an oil pressure gauge to a TC88 and on hot days at idle at red light it would read just about zero, but I knew that was normal and didnt freak out about it. Bike now has 80K miles and going strong
AJDR^ is offline
post #7 of 7 (permalink) Old 11-13-2019, 10:20 AM
craigffb's Avatar
I could be wrong, but I don't think the Distance Till Empty shows up in the Engine Info pages either. At least I've never noticed it.
