PCV Mapping - Road Glide Forums
Map Section Exchange mapping here. Please be careful when exchanging maps, we assume no liability or responsibility for faulty or defective maps. Exchange at you own risk.
post #1 of 8 (permalink) Old 02-05-2012, 05:10 PM Thread Starter
HoboCoastie's Avatar
Question PCV Mapping
I finally took the plunge and bought some horses!
-V&H Power Duals Header
-V&H Hi-Output Slip-Ons
-PCV
I already have a SE Stage 1 AC.
The parts aren't here yet, but I'd like to have a map waiting when they get here.
On PC's website they have a couple maps listed that are close...
15-011-073
Vance & Hines Power Duals
Vance & Hines Monster Rounds mufflers
Screamin' Eagle air filter
15-011-064
Vance & Hines Monster Ovals
Neither of these specify the 103" motor and the maps that do aren't even close to what I have.
I've already e-mailed PC's Tech Support, but being Sunday I haven't heard back yet, but I figured I could bounce it off you guys and see if anyone has the same configuration and see what map they're using.
Thanks!
Hobo
Official Herd #00151
Patriot Guard #216365
, V&H Power Duals, V&H Hi-Outputs, PCV, 2" Tank Lift, Various Bling
HoboCoastie is offline
post #2 of 8 (permalink) Old 02-06-2012, 07:30 AM
Gonekat's Avatar
when i mapped mine, I went to the PC site and toward the end of the list of maps was the 103 section.
2011 RGC, Sedona Orange 103" w/ 48H cams,PM Icon 21" wheel,Kury Mach 2 intake,Jackpot 3.5, PM brake and shift levers, CB 14" TRSSC shield, Sinister 14" apes, custom levers.Black exhaust,floorboards,pegs and crash bar.
Gonekat is offline
post #3 of 8 (permalink) Old 02-06-2012, 09:12 AM
laxinharley's Avatar
True. Yes you have to go all the way down and thiere is a 103" section. I have an arlen ness big sucker, Vance and hines pro-pipe and the PCV. I chose the closest one which was a 103 with arlen ness big sucker, and the rinehart 2 into 1 because they didn't have the V and H 2 into 1. The bike runs great.
laxinharley is offline
post #4 of 8 (permalink) Old 02-08-2012, 07:09 PM Thread Starter
Well, at the behest of PC tech support, I loaded Map #15-011-076. It's for 103" model, Rinehart Classic True Duals with 4" mufflers Screamin' Eagle air filter. The guys said the flow characteristics should be very similar.
It seems to work pretty well. I do get some back firing when squeezing the clutch and rolling off from higher rpm's.
With most HD models featuring the 103, I look for there to be a surge in mapping from PC.
Hobo
post #5 of 8 (permalink) Old 06-05-2012, 12:12 PM
PCV Mapping...
I have a similar setup... V&H Power header and Supertrapp slip-ons with 10 discs installed. As well as a SE intake kit. I went with a map that showed the V&H Power header and Rinehart Slip-ons with a breather and get some popping when I decel. Not sure if anyone out there has done mapping and has something to offer but I am open to suggestions...
Mike.
mjohnson68 is offline
post #6 of 8 (permalink) Old 06-05-2012, 12:20 PM Thread Starter
I ended up switching to this one:
15-011-034 Electra Glide Ultra Limited, 103" engine, Vance & Hines Power Duals with Monster Ovals, Screamin Eagle air filter, Table 1 is front cylinder
More closely matches my setup.
Hobo
post #7 of 8 (permalink) Old 06-05-2012, 04:27 PM
Dickie's Avatar
Mike.
Decel popping is caused by too much or not enough fuel in the closed throttle position. Take note what rpm range it occurs and add or subtract fuel in the zero column in that rpm range,till it is not occurring. Sometimes to +/- 25. Check this website for more info. http://www.ultraboy.us/
2017 FLTRU
Dickie is offline
post #8 of 8 (permalink) Old 02-13-2016, 12:09 PM
I found a lot of useful information, thank you guys!
hunt85 is offline
Changed Thundermax Mapping and mileage increased 1BadGlide Map Section 3 08-01-2014 08:52 AM
Fuel Moto mapping - no CD Clutch1 ECM/Fuel Management systems 2 01-04-2013 02:04 PM
Help me understand EFI & Mapping Please G ECM/Fuel Management systems 7 02-11-2011 11:48 PM
Best Mapping Program for MAC stewarrd *General Road Glide Discussions/Pictures 2 11-28-2010 10:36 AM
