107ci,dragos 580 cams - Road Glide Forums
Map Section Exchange mapping here. Please be careful when exchanging maps, we assume no liability or responsibility for faulty or defective maps. Exchange at you own risk.
post #1 of 15 (permalink) Old 05-26-2014, 02:44 PM Thread Starter
pat123's Avatar
Anybody have a powervision map for
107ci
Dragos 580 cam
10.5:1 compression
Dragos h pipe and dragos slip ons
I got a map from frank but since it's getting warmer lately it's pinging like a SOB
I have a appt with a tuner this week but I want to ride it.
Thanks
pat123 is offline
post #2 of 15 (permalink) Old 05-26-2014, 10:48 PM
rageglide's Avatar
107ci
Dragos 580 cam
10.5:1 compression
Thanks
Did you run autotune just to fine tune for your combo? I would talk to Frank that's his recipe and products, best place to get info.
2012 fltrx
rageglide is offline
post #3 of 15 (permalink) Old 05-26-2014, 11:01 PM Thread Starter
pat123's Avatar
Yes I have tried many auto tunes (pro) with no dice. It pings like crazy. I'm sick of messing with it. I have a appt with a tuner this week. If I was closer to frank I would just bring it to him.
pat123 is offline
post #4 of 15 (permalink) Old 05-26-2014, 11:11 PM
rageglide's Avatar
Sounds like the best plan really. Franks map will be a good starting point.
2012 fltrx
post #5 of 15 (permalink) Old 06-20-2014, 10:57 AM
Wildmank99's Avatar
Pat any luck from Frank on the map?
Wildmank99 is offline
post #6 of 15 (permalink) Old 06-20-2014, 11:24 AM Thread Starter
pat123's Avatar
Yes. I got one from frank.it was close but It really need to be tuned. I couldn't find anyone local to tune a powervision. Can you believe that? No one in the Atlanta area. Everyone I called asked what's a powervision. I found one guy but when I went to drop it off he was injured in a car accident and couldn't do it. What can you do? I needed to leave on vacation with the bike so I tore it down and put the stock jugs and heads on it. It rode GREAT!!
That S&S 124 is calling my name. Just might order it. I'll end up towing it to frank or DOC in Florida to tune it.
pat123 is offline
post #7 of 15 (permalink) Old 06-20-2014, 11:51 AM
Word of advice, if you go to DOC he won't touch any bike that doesn't have the TTS, no other tuner exist as far as he's concerned.
post #8 of 15 (permalink) Old 06-20-2014, 11:57 AM Thread Starter
pat123's Avatar
That's what Frank told me but he's the best in the business from what I have heard.
pat123 is offline
post #9 of 15 (permalink) Old 06-20-2014, 12:09 PM
He's good, and said by some to be the best with the TTS.......if I remember correctly he either helped or designed it, so he should be the best. I'm not knocking him, but there are a lot of good strong running bikes out there, and they didn't all come from central Florida. If you want to change tuners and go with the TTS, then by all means go to DOC, if not, I'd seek out another source. IJS..... let us know what you do, and however it turns out, I wish you luck.
post #10 of 15 (permalink) Old 06-20-2014, 12:46 PM
Redbeard77's Avatar
How far are you from Pearl, MS? Fuel Moto recommends Gary Williams, so check with him on tuning.
Originally Posted by fuelmoto View Post
Also note that for those in the southern part of the USA professional installation is available by Gary Williams at Williams Carburetors in Pearl, MS. Gary has extensive experience with our kits and has been building a couple of our 107's a week. He can be located here http://www.williamscarburetors.com/
Happiness is a warm motorcycle.
Redbeard77 is offline
2012 Dragos 580 cam, Dragos 2, TTS hd4cruzin Dyno Results 20 05-05-2015 09:26 PM
New Dragula 2 pipe and Dragos 580 bolt in cams DragoBikeWorks Engine Related 16 11-19-2014 12:08 AM
Dragos 580 cams,woods lifters and FM adjustable pushrods. pat123 Parts for Sale 0 07-27-2014 02:26 PM
