Retune or not? - Road Glide Forums
Map Section Exchange mapping here. Please be careful when exchanging maps, we assume no liability or responsibility for faulty or defective maps. Exchange at you own risk.
post #1 of 5 (permalink) Old 06-14-2014, 06:17 PM Thread Starter
SmokeyJoe's Avatar
Retune or not?
Looking for some advice. I am planning a trip which will take me from my normal elevation (350 feet) to around 6000 feet. I have a Power Vision and could do a retune on the fly if needed, but I am curious if this is even needed?
SmokeyJoe is offline
post #2 of 5 (permalink) Old 06-14-2014, 07:56 PM
mitchdm's Avatar
The short answer is no. However you may choose to do it ~ remember your bike will never run as strong at higher elevations. I like to look at the afr's and frequently play with the tune ~ but the reality is at higher altitudes you should be good to go.
mitchdm is offline
post #3 of 5 (permalink) Old 06-14-2014, 08:00 PM
throttles&triggers's Avatar
Absolutely not...I have run at elevations from sea level to over 14,000 feet on several different motorcycles and never had an issue with any, all of which were injected and two of which had aftermarket tuner kits. Your CVO shouldn't even notice a change to 6,000'.
throttles&triggers is offline
post #4 of 5 (permalink) Old 06-14-2014, 09:14 PM
No need to do anything! The O2 sensors will do all the adjusting for elevation changes.
post #5 of 5 (permalink) Old 06-15-2014, 02:32 AM Thread Starter
SmokeyJoe's Avatar
Cool, thanx
Retune of stock ECM?? krugs71 ECM/Fuel Management systems 8 07-07-2015 11:18 AM
decatting retune or not??? 09bonescanada Intake and Exhaust 5 07-31-2014 10:29 PM
Changed to Non-Cat Headers - Need to retune? trakkon Intake and Exhaust 8 07-14-2014 09:02 PM
Retune after mild head porting??? Reddobe1 Engine Related 11 01-21-2014 08:12 AM
To retune or not retune, that is the question pab Intake and Exhaust 5 01-08-2014 07:30 PM
