Changed Thundermax Mapping and mileage increased - Road Glide Forums
Map Section Exchange mapping here. Please be careful when exchanging maps, we assume no liability or responsibility for faulty or defective maps. Exchange at you own risk.
post #1 of 4 (permalink) Old 07-09-2014, 12:26 PM Thread Starter
Hello,
After reading quite a bit about the Thundermax, I decided to make some changes to my Thundermax map #345. In the stock map, some AFR ratios were around 2.8, while at cruise they were in the mid to upper 13's. This gave me horrible mileage, somewhere in the 20 mpg range. After reading quite a bit, I decided to change the curves at every rpm and raised the whole curves. Most of my cruising AFR's are in the 14.1-14.2 range with the rest of the curve in the lost 13.2's to 13.3's. This has made a dramatic improvement up to around 39 mpg. Bike seems to be running great. Does not seem to have any excessive heat, no knock or pinging. My bike is a 2009 SERG with a 110 motor, stock cams, Vance & Hines Power dual head pipe, V & H Hi Output mufflers, Screamin Eagle High Flow air cleaner. I have checked the plugs and they are mostly brown with a slight white possible at the tip. Do you think this is going to be OK? I do not want to lean it out too much.
Thanks,
1BadGlide
1BadGlide is offline
post #2 of 4 (permalink) Old 07-30-2014, 07:57 PM
mitchdm's Avatar
I think 14.1 to 14.2 is fine ~ if the bike is running good with no pinging I don't see a downside.... I have the afr's set in my PCV with AT at 14 at cruise with the S&S 124.
mitchdm is offline
post #3 of 4 (permalink) Old 07-30-2014, 08:14 PM
tdkkart's Avatar
I fail to see the reason "tuners" feel the need to drown the engine in fuel.......and why they think 25mpg is perfectly acceptable. I see way too many bikes that blow black smoke every time the rider cracks the throttle. "Hey bud, it's not a diesel............"
tdkkart is offline
post #4 of 4 (permalink) Old 08-01-2014, 08:52 AM
fltru103's Avatar
Diffidently what he said ^^ ...
I changed to Drago's true duals, PV and a high flow air cleaner. Told Frank I wanted quiet mufflers and my great fuel mileage with the supplied tune.
I got it. Mileage might have dropped 1 to 3 mpg, but not anymore then that. Still running very high 40's with great power and nice sound.
There is a happy medium with fuel and air.
No need to dump excessive fuel.
That is what computers have given us. The ability precisely meter the correct amounts for performance and economy.
in my garage now...
2007 Dyna Screamin Eagle ... SOLD !
2011 RGU Merlot SunGlo
fltru103 is offline
Increased vibration Brianu1 Engine Related 12 10-27-2014 06:05 PM
Fairing lower increased temps. JSCHWAG Engine Related 19 09-18-2014 09:00 PM
Best Mapping Program for MAC stewarrd *General Road Glide Discussions/Pictures 2 11-28-2010 10:36 AM
