Map help!!!!!! - Road Glide Forums
Map Section Exchange mapping here. Please be careful when exchanging maps, we assume no liability or responsibility for faulty or defective maps. Exchange at you own risk.
  • 1 Post By ironmark
post #1 of 3 (permalink) Old 09-11-2014, 07:02 PM Thread Starter
TYM2GLIDE's Avatar
Map help!!!!!!
I have a 2012 FLTRX that was DYNO tuned. I have been experiencing excessive "blow-by" recently with my Arlen Ness big sucker air cleaner. I want to change to a Vance and Hines "naked" air cleaner. Will i need to get it re-tuned or is the intake relatively the same?
I currently have the HTC Jackpot header, rinehart 4in cans.
Thanks in advance.
Semper Fi
Scott
2012 FLTRX, 4" Rineharts, V&H Naked V02, FullSack Head Pipe, 14" Malo's, Topshop Minister Fender & Viper bags, 21in Hogpro Titan wheel, Progressive monotubes with 1in drop, Andrews 57H cams.
TYM2GLIDE is offline
post #2 of 3 (permalink) Old 02-24-2015, 09:40 AM
UltraNutZ's Avatar
if you have excessive blow-by, a new A/C nor a map is going to help you. You need to find the root cause of your issues.
2012 FLHTK - VTPBB
UltraNutZ is offline
post #3 of 3 (permalink) Old 02-24-2015, 11:43 AM
In most cases oil in the air filter is because there is too much oil in the crankcase, 3 1/2 qts when doing a oil change is all that should be put in the engine.
If you still have too much oil in the air filter after the oil level has been adjusted then you may have a problem with the umbrella valves in the crankcase breathers.
No you won't have to re-tune after changing the intake systems, changing intakes will not stop the oil in the air filter problem.
G5Driver likes this.
Need map and have map to share Hack73 Map Section 0 10-03-2016 05:42 AM
Please help with my map justincollins ECM/Fuel Management systems 10 12-22-2012 09:40 PM
What Fuel Moto MAP are you using??? Help Jamie or anyone? CaptJim1954 ECM/Fuel Management systems 10 03-05-2012 10:56 AM
PC-V Map help Luscruz ECM/Fuel Management systems 3 06-25-2011 11:03 AM
Help w/Map for PCV sftosendai ECM/Fuel Management systems 6 06-16-2011 10:31 AM
