Rush Reaper system K&N air charger PCV MAP? - Road Glide Forums
Map Section Exchange mapping here. Please be careful when exchanging maps, we assume no liability or responsibility for faulty or defective maps. Exchange at you own risk.
post #1 of 10 (permalink) Old 06-26-2012, 03:32 PM Thread Starter
BACA POPEYE's Avatar
This is a 2 into one system with a 3 inch baffle, PC has a map for a 2 into 1 Rush system with SE air intake on a 103". Should this be close enough?
It's not the man who points out how the strong man stumbles. The credit belongs to the man who's actually in the arena, face marred by dust, sweat and blood who errs, and comes short again and again, who knows the great enthusiasms and devotions, spends himself in a worthy cause; who knows the triumph of high achievement, and who if he fails, at least fails while daring greatly, so that his place shall never be with those cold and timid souls who know neither victory nor defeat.
BACA POPEYE is offline
post #2 of 10 (permalink) Old 06-26-2012, 07:51 PM
Triplej's Avatar
You would probably be good with either one of these but I would try both and see which one the bike prefers.
15-011-083 103" model, Rush 2 into 1 full system with 2.5" baffle Screamin Eagle air filter
15-011-068 Rush 2into1 exhaust (2.50" baffle) Screamin' Eagle air filter Stock ECM
Triplej is offline
post #3 of 10 (permalink) Old 06-27-2012, 08:57 AM
The map that PC is for there std 2.1 not there 3 step header. It will be off....
DragoBikeWorks is offline
post #4 of 10 (permalink) Old 06-27-2012, 09:29 AM Thread Starter
Thats what I was afraid of, do you have a suggestion I know you have the same pipe available.
post #5 of 10 (permalink) Old 06-27-2012, 09:31 AM Thread Starter
Also do you happen to carry the 2 1/4" baffle for that pipe?
Mine is coming with the 3" and I believe that will cause some loss for me.
post #6 of 10 (permalink) Old 06-27-2012, 10:41 AM
The pipes are different. I was on this R&D of this pipe.
You will have to call me. What size motor do you have 103 stock?
post #7 of 10 (permalink) Old 06-27-2012, 11:30 AM Thread Starter
Yes stock 103, PCV, k&n mass flow air, and will be putting reaper 3 stage with 3" baffle.
post #8 of 10 (permalink) Old 06-28-2012, 08:04 AM
I can send you a map that might help you with there 3 inch until you get a 2.25 send email over.
post #9 of 10 (permalink) Old 06-28-2012, 09:49 AM Thread Starter
You can reach me at [email protected]
post #10 of 10 (permalink) Old 06-28-2012, 09:50 AM Thread Starter
Oh and thanks again for the help and advice! I wish I had paid more attention to this forum I would have ordered from you, but I will tell others that you are the guy to talk to.
Need map for 2010, 96", v&h dresser duals, rush 3.5", 2" baffle ilmanzo31 Map Section 3 07-28-2016 03:52 PM
aero charger vs pro charger grindle19 Engine Related 9 10-28-2015 12:56 AM
2008 stock with Feuling 525 reaper cam stock header Rush mufflers 1.75 baffle DragoBikeWorks Dyno Results 6 09-13-2012 05:19 PM
Map for 2011 103 RG, PCV, V&H pro-pipe, and SE air cleaner? sdlakerfan79 ECM/Fuel Management systems 4 12-28-2011 12:10 PM
Kuryakyn Pro Series Hyper Charger Air Cleaner Chaddy-P Classifieds Archive (3 months old+) 2 12-08-2011 08:15 AM
