Andrews 57h powervision map - Road Glide Forums
Map Section Exchange mapping here. Please be careful when exchanging maps, we assume no liability or responsibility for faulty or defective maps. Exchange at you own risk.
post #1 of 2 (permalink) Old 02-24-2016, 07:35 PM Thread Starter
boomerman's Avatar
Need Andrews 57h powervision map/tune
Does anyone have a powervision map for the Andrews 57H cam with screamin eagle air filter, rush exhaust and stock non catted head pipes?
Anything close would be good as well.
Thanks
boomerman
2012 Road Glide Ultra Big Blue Pearl
1999 Dyna SuperGlide Black
boomerman is offline
post #2 of 2 (permalink) Old 02-24-2016, 08:14 PM
hifiho's Avatar
I've got a carb'd Softail, that had the Andrews 57G cams. Swapped 'em out for S&S "easy start" cams of similar profile. Just had to change the needle in the carb, and adjust the idle and timing. I like the reliability and start-ability of the FI bikes, but damn it's nice to tune with hand tools! And a helluva lot cheaper!
I know I'm no help. Just sayin'.....
'15 Road Glide Special...'08 Night Rod Special...'04 Stage 4 113 CI Softail Deuce (Beast Mode)
hifiho is offline
Andrews 57H Cams-What pipes are you running? LM1976 Intake and Exhaust 7 05-11-2014 07:00 PM
Andrews 57H Installed PauleyB Engine Related 11 03-31-2014 07:37 PM
2011 FLTRX Andrews 57H vaughtcity Dyno Results 2 11-08-2013 11:24 AM
Andrews 57H cams ShitHouseRat Sold 6 09-11-2013 08:33 PM
Andrews 57H ShitHouseRat Engine Related 56 08-12-2013 09:29 PM
