TTS Mastertune BreakIN Tune??? - Road Glide Forums
Map Section Exchange mapping here. Please be careful when exchanging maps, we assume no liability or responsibility for faulty or defective maps. Exchange at you own risk.
 3Likes
post #1 of 12 (permalink) Old 02-14-2017, 02:43 AM Thread Starter
Can anyone point me in the right direction of a good break in tune for the TTS mastertune?? Im having the dealer build my bike but they are not familiar with these. I spoke to the dyno/tune man and he told me I need a break in tune for the bike and I could just do that myself or I could bring it to him for a cost of $400....I really dont want to have a freaking $1000 in tuning my bike. I don't mind the $500 for dyno and final tune but just to get me 800-1000 miles for break in I believe is a little rediculous.
This is my engine specs for my 06 RG FLTRI TC88 build:
95" jugs
SE roller rockers,SE 251 cam,SE PRO Kompressor Heads 10.5/1 CR
D&D FatCat 2:1 perf baffle
TTS Mastertune
Any help will greatly be appreciated.
06 FLTRI- SE 95'',SE 251 cams,SE PRO Kompressor 10.5:1 Heads w/manual CR,TTS Mastertune,D&D FATCAT 2:1
12" KlockWerks, 10" MeatHooks, LiteWay Dual 7" Daymaker LED Projectors, JVC Headunit, Rockford 6.5'sx2 fairing mounted, Rockford 6x9'sx2 bag lids, Fosgate 400w fairing mounted amp
Iron1 is offline
post #2 of 12 (permalink) Old 02-14-2017, 06:57 AM
Who is going to tune it? A good tune will take 6 hours! that is your break in time. ( tuning all cells front cylinder then rear cylinder both cylinders together. A couple good pulls adjust everything again. ( hours) you are paying 400.00 for a tuner make sure you get a good tune.
dozer23 is offline
post #3 of 12 (permalink) Old 02-14-2017, 07:15 AM
Find a tts tune that is close to your build flash it use the flight recorder run several short runs in different rpm's and download each run do this several times will be a good way to break it in,Then take it to a tuner for final tune cost is low this way.
Iron1 likes this.
steve2100 is offline
post #4 of 12 (permalink) Old 02-14-2017, 09:08 AM
Smarty's Avatar
95" jugs
TTS Mastertune
If the heat cycles are done right, then put on the dyno and tuned for cold idle, hot idle, then 5,10, 15% throttle always taking note of engine temp and head temp, by the time the tuner gets to the 25% and on up, it should be ready for a full on tune. I don't see a necessity for a 1000 mile break in. We've been tuning this way forever as have other tuners. As long as you start out with a good download that is fairly close it will come out perfect and should have no problems.
2016 RGS Black Quartz
Smarty is offline
post #5 of 12 (permalink) Old 02-14-2017, 10:34 AM
mastergunnera8's Avatar
What type of tuner does the dealer use normally? I would recommend using that.. if you didn't buy the TTS already
mastergunnera8 is offline
post #6 of 12 (permalink) Old 02-14-2017, 08:26 PM Thread Starter
The dealer flat out told me that what they sell is the SE tuners and they are junk now. He said for my build the PC5 would be a good one to get me going because his tech knows how to set it kinda decent. The dealer has a guy who does all their performance tuning and dynoing and he's the guy I've been told to go to by very many people. I spoke to him, the tuner, and he said he could tune any but the TTS is by far the best with having more places to calibrate. He told me all about the difference of them and I figure if he knows the TTS that well then I'd go with it. He said to start with it just needs set to the cold start settings and ran that way during break in then bring it to him for the final tune.. I'm dealing with Boswells HD in Nashville TN and my tuners name is Conrad at T&T performance. I could've tuned the PC5 myself as it only has a few variables and I've used one before but this TTS IS COMPLICATED FOR PERSONAL NO DYNO TUNING. If it comes down to it I'll just take it to him. He promises me that if I do it his way that I will have a well broke in engine before ramping it up to high rpms. Me personally will never believe that one can be broken in on the dyno. I mean all those new components don't need to be in a hard pull before it's all seated up. I've built engines for years and I'm a mechanic everyday by trade but this is my first harley davidson build and to use a tuner capable of what the TTS is...The tuner told me that TTS built the SERT to begin with.
mastergunnera8 likes this.
Iron1 is offline
post #7 of 12 (permalink) Old 02-14-2017, 09:59 PM
Ohiobellboy's Avatar
Contact Steve Cole at TTS and let him know what your build is. He should have a map he can email you to get started with. http://www.mastertune.net/
turbochrisb likes this.
A.K.A OBB
Ohiobellboy is offline
post #8 of 12 (permalink) Old 02-15-2017, 01:04 AM
Smokey's Avatar
Originally Posted by Ohiobellboy View Post
Contact Steve Cole at TTS and let him know what your build is. He should have a map he can email you to get started with. MasterTune by TTS Inc.
+1
Smokey is offline
post #9 of 12 (permalink) Old 02-16-2017, 02:06 AM
turbochrisb's Avatar
I used TTS in my build. I used a VERY reputable tuner here locally. I trailored the bike to him and he installed a break in tune....ran pretty shitty...but I put 300 miles on it and brought it back for final tune. All for $400. That IS the going rate. NOT double that.
turbochrisb is offline
post #10 of 12 (permalink) Old 02-16-2017, 06:59 AM
Dude if your tuner - builder dosn't have a map for the bike so he can start the tune maybe you should ask around and find a qualified TTS tuner.the bike will not need a 1000 mile break in as I said before if tuned properly break in will be on the dyno.
A BIKE CAN NOT BE TUNED PROPERLY IN LESS THAN 4 HOURS I DON'T CARE HOW CLOSE THE STARTING MAP IS AND IF ANYONE TELLS YOU DIFFERENT THEY ARE LIARS EVERY ONE OF THEM!
IF THE TUNE TAKES LESS THAN THAT THE TUNER DECIDED IT IS ( CLOSE ENOUGH )
dozer23 is offline
TTS MASTERTUNE w/ Software and TTS USB cable. Raiderse Classifieds Archive (3 months old+) 0 05-17-2012 05:08 AM
TTS MasterTune Map to stop Ping and high heat 2011 RGU? Raiderse ECM/Fuel Management systems 15 05-10-2012 02:52 PM
TTS mastertune schuldtp ECM/Fuel Management systems 16 01-17-2012 09:24 PM
TTS Mastertune & a New Header Martin ECM/Fuel Management systems 5 06-25-2011 06:33 PM
Get a great deal on TTS MasterTune BDMastiff Engine Related 35 05-28-2011 08:22 AM
