Delta % from canned map after autotune - Road Glide Forums
Map Section Exchange mapping here. Please be careful when exchanging maps, we assume no liability or responsibility for faulty or defective maps. Exchange at you own risk.
post #1 of 1 (permalink) Old 05-06-2017, 06:02 PM Thread Starter
After getting the canned map from FM i did a couple of autotune sessions (O2 stock), just to be sure that the map would fit the bike perfectly.
bike runs smooth, the front VE is now richer in the 2000-4000RPM of an average 8-10% while the rear is leaner with an average 6-8% if compared with the canned map initial values.
Did you experienced the same results? would be better to keep the canned map for a better balance between the 2 cylinders?
Beaver is offline
FP3 canned map advice canukHD ECM/Fuel Management systems 6 05-16-2018 02:30 PM
Canned SE Map. What am I leaving on the table? bikepsych ECM/Fuel Management systems 11 04-04-2018 07:26 AM
“Close” canned PV tune safe enough for new cams? mchad ECM/Fuel Management systems 1 03-28-2018 12:11 PM
Need map and have map to share Hack73 Map Section 0 10-03-2016 05:42 AM
Happy Canned Beer Day!!! OldNerdGuy General Off-Topic Discussions 11 01-24-2013 07:31 PM
