SERT Map needed 2012 103" - Road Glide Forums
Map Section Exchange mapping here. Please be careful when exchanging maps, we assume no liability or responsibility for faulty or defective maps. Exchange at you own risk.
post #1 of 5 (permalink) Old 03-26-2013, 07:17 PM Thread Starter
scooterroid's Avatar
SERT map need for for the folllowing setup:
2012 103", 254e cams, SE Heavy Breather, Drago's 2:1
Thanks in advance, Scoots
scooterroid is offline
post #2 of 5 (permalink) Old 05-06-2013, 01:18 AM
Taccone's Avatar
You ever get a map for this combo? Or did you dyno tune it?
Taccone is offline
post #3 of 5 (permalink) Old 05-08-2013, 03:34 PM Thread Starter
I've had it dyno tuned at 2 different places with basically the same results with my current set up which is the same except I currently have V&H Big Radius pipes. I plan on buying a Dragula 2-1 in the near future. If anyone already has a map for this combo, then that would would save me a few $$$ for another dyno tune. So far no luck.
post #4 of 5 (permalink) Old 05-09-2013, 01:18 AM
Taccone's Avatar
I have a similar setup, just different pipes I'm running CFR's but identical cam and I have the SE heavy breather intake, just got it dyno'd you having prob's with the bike? or not happy with the numbers?
Taccone is offline
post #5 of 5 (permalink) Old 05-11-2013, 06:15 PM Thread Starter
Sert map needed.......... BAM BAM Map Section 6 07-15-2013 10:58 PM
103", VH Power Duals, Rhineheart 4" Mufflers, SERT, SE Air Schnorkle, SE259E cams. CajunAg Dyno Results 3 05-25-2013 11:54 PM
Base map for SERT Too Short Intake and Exhaust 0 07-23-2012 08:40 AM
Question on SERT map for 2010 Too Short ECM/Fuel Management systems 0 07-15-2012 02:23 PM
Dropping a map into a SERT BigDaveOnBass ECM/Fuel Management systems 0 02-28-2011 08:52 AM
