s&s 510 cams - Road Glide Forums
Map Section Exchange mapping here. Please be careful when exchanging maps, we assume no liability or responsibility for faulty or defective maps. Exchange at you own risk.
post #1 of 2 (permalink) Old 05-26-2017, 08:30 PM Thread Starter
s&s 510 cams
anybody running the 510 cams and need a map I have one my setup is; 2013 103 rush headers 4.5'' slip ons stage1 a/c with that being said my indy installed dynoed bike with my power vision to the tune of 100.00 hp 111.63 torque! he played with timing and gave it a nasty lope at idle 1000rpm when set up but now at 952 more lope!!!!!!!
rebeltitanfan63 is offline
post #2 of 2 (permalink) Old 06-09-2017, 02:45 PM
SMOKENJOE's Avatar
SEEMS LIKE YOU DONT NEED A MAP AS YOU HAD IT DYNO TUNED HE SHOULD HAVE SAVED THE INFO OFF THE TUNE
510: Designed as a bolt-in cam for 88, 95, and 96 CID engines with compression ratios below 9.7:1, it is primarily intended for use with stock, un-ported heads. 3000-5500 rpm. Bolt-in overall.
SMOKENJOE is offline
s&s 510 cams rebeltitanfan63 Dyno Results 0 01-24-2018 02:07 PM
S&s97, Ams 84cc heads, cobra power flow, propipe with race baffel, 510 gear cams, s&s 02RG97BB Dyno Results 0 02-13-2015 10:01 AM
s&s 510 review jimmyray11349 Engine Related 7 10-17-2011 10:04 AM
s&s 510 review jimmyray11349 *General Road Glide Discussions/Pictures 0 10-16-2011 09:00 AM
Cams S&S 510 help jimmyray11349 *General Road Glide Discussions/Pictures 7 10-14-2011 04:33 PM
