2013 RG PV Map needed for 57H Cams - Road Glide Forums
Map Section Exchange mapping here. Please be careful when exchanging maps, we assume no liability or responsibility for faulty or defective maps. Exchange at you own risk.
post #1 of 19 (permalink) Old 04-22-2013, 03:00 PM Thread Starter
Deadstroke's Avatar
I have franks pipes and a heavy air breather and going with the andrews 57H cams.. Looking for a PV MAP
thanks
Deadstroke is offline
post #2 of 19 (permalink) Old 04-22-2013, 03:14 PM
X In Black's Avatar
Looking forward to hearing your opinion, Deadstroke.
2012 FLTRX
Rinehart 2 Into 1|Ness Big Sucker AC|Andrews 57H Cams|PowerVision
X In Black is offline
post #3 of 19 (permalink) Old 05-08-2013, 09:21 AM Thread Starter
Deadstroke's Avatar
Doing the install on friday so we will see
post #4 of 19 (permalink) Old 05-11-2013, 05:05 PM Thread Starter
Deadstroke's Avatar
Tunes are not working out.. bike is bogging at 2500 to 2700 rpms running really rough..
post #5 of 19 (permalink) Old 07-27-2013, 11:20 PM
sampson104's Avatar
Mine is doing same thing right around there, it's like I hit the kill switch, did you get this figured out? Put the same cams in on Thursday.
sampson104 is offline
post #6 of 19 (permalink) Old 07-28-2013, 01:54 AM Thread Starter
Deadstroke's Avatar
yep the o2 sensors were backwards... something so simple caused so much issue lol
post #7 of 19 (permalink) Old 07-28-2013, 03:20 AM
mitchdm's Avatar
DeadStroke ~ L&R ~ just an FYI ~ If you have the PCV why not add the autotune ~ I added this a few days ago ~ no base map needed ~ ride like ya do and accept the trims ~ have had it on my last two scoots for 160k + collectively and very please with the PCV and the autotune ~ SemperFi ~ FM sent the PCV to me with a 0 map since I was not sure of the headwork or cams.
mitchdm is offline
post #8 of 19 (permalink) Old 07-28-2013, 09:51 AM
sampson104's Avatar
So your back I'm business now and it's running smooth, idle to 5,500?
post #9 of 19 (permalink) Old 07-28-2013, 12:18 PM Thread Starter
Deadstroke's Avatar
Running like a champ, I Run it up to 6k and no hesitation.. cam kicked it at 2800 and at over 3k it shines.. Also getting about 37-40mpg
post #10 of 19 (permalink) Old 06-07-2014, 06:17 PM
Wmoor004's Avatar
I sure would love that map! Lol
Wmoor004 is offline
Andrews 57h powervision map boomerman Map Section 1 02-24-2016 08:14 PM
Power Vision Map needed 107"/ 57h, 2-1, heads Easyryder01 Map Section 1 02-15-2015 10:20 PM
PV map for 106/107 kit, 57H cams and heads mffi497 Map Section 1 11-25-2013 10:00 AM
2011 rgu true duals 57h need PCv map gibrj Map Section 1 09-02-2013 10:18 AM
2006 PV 1 map needed. satwatchers Map Section 3 03-16-2013 04:00 PM
