PC V se254 cam rhinehart map needed - Road Glide Forums
Map Section Exchange mapping here. Please be careful when exchanging maps, we assume no liability or responsibility for faulty or defective maps. Exchange at you own risk.
post #1 of 6 (permalink) Old 08-10-2013, 08:59 PM Thread Starter
Easyryder01's Avatar
Disregard this thread I switched over to a Power Vision.
2017 RGS Velocity Red
Easyryder01 is offline
post #2 of 6 (permalink) Old 08-12-2013, 11:07 PM
scooterroid's Avatar
I'm game. Send your map, I'd like to see it maybe give it a try. Which Rineharts do you have?
Scoots
scooterroid is offline
post #3 of 6 (permalink) Old 08-13-2013, 06:58 AM Thread Starter
I have no idea how to retrieve the map out of my PCV. Let alone put another one in. I have 4" Reinharts.
post #4 of 6 (permalink) Old 08-13-2013, 10:33 AM
DED HD's Avatar
if you have the Dyno jet software on your laptop, the map will be stored in a file on your computer.
Its easy as emailing any attachment. PCV files are .pvm files.
If you havent downloaded the software onto your laptop or computer- do so, and can easily adjust your map, or download other maps either onto your laptop, or actually run it on your bike. The PCV only holds one map, but will not get lost if you save it onto your computer.
You may want to check out Dynojets website for a map with your configuration and see if it runs better.
Do you have the Rinehart 4" slip ons installed on a stock header or what header are you running?
'10 Red Custom:
DED HD is offline
post #5 of 6 (permalink) Old 08-13-2013, 11:02 AM Thread Starter
I have to download the software on my laptop. Maybe I'll just get on the phone with dynojet and they can walk me through on how to retrieve the download from my PCV. Thread pipe I have is a fullsac sport pipe. ....which is basically a stock head pipe with the cat chopped out completely and an x pipe welded in its place. Its over a hundred bucks cheaper than there x pipe and only 1hp difference between the two.
post #6 of 6 (permalink) Old 08-13-2013, 06:30 PM
My bad. I have SEPRT. I'm out but still interested in how your tune goes. I had my bike dyno tuned at 2 different HD shops and the results were crappy. Finally I downloaded a new map and tweaked it a little and so far I'm very happy. Just wasted my $$$ at HD.
254e
Heavy Breather
V&H Big Radius
Scoots
PC Map Needed sldmedic Map Section 1 05-05-2013 09:48 PM
Bassani & se254 Phil-Az Intake and Exhaust 1 03-11-2013 12:58 AM
PC-V Map Needed for V&H Set-up Agent Joe Map Section 5 12-08-2012 06:59 AM
PC-V Base Map needed Hullhorr Map Section 0 10-22-2012 02:20 PM
pc iii map needed 07 deluxe with 48cam bigpete1 Map Section 1 06-25-2012 08:53 AM
