2011 rgu true duals 57h need PCv map - Road Glide Forums
Map Section Exchange mapping here. Please be careful when exchanging maps, we assume no liability or responsibility for faulty or defective maps. Exchange at you own risk.
post #1 of 2 (permalink) Old 08-30-2013, 09:59 AM Thread Starter
gibrj's Avatar
Hi all. I have a 2011 rgu with V&H true duals, monster ovals, arlen ness big sucker. I am getting ready to install the Andrews 57h cams. I have the PCv with auto tune and am looking for a new base map for after my cam install.
Also, any thoughts if it would be worth upgrading to a PV? Will the PCv autotune work with the PV? Can a PV map be loaded to a PCv and visa-versa?
2011 RGU, V&H true duals, monster ovals, big sucker, pcV w/ auto tune, 11 & 15 LRS, 13" LA prime apes, much more!! Quit? When I'm 6 foot under.
gibrj is offline
post #2 of 2 (permalink) Old 09-02-2013, 10:18 AM Thread Starter
gibrj's Avatar
Anybody got a map for anything close? I plan on getting a dyno later, but would like to use auto tune for a while first just to compare final results. Planning cam swap mid to late September. Thanks
gibrj is offline
PCV Tuning for Andrews 57h in 2015 Radar ECM/Fuel Management systems 5 09-12-2016 12:50 PM
Need a 117 base map for pcv tman 625s and worked heads any 117 mapwill work using aut mitchdm ECM/Fuel Management systems 3 05-16-2014 10:31 AM
Thunderheader true duals/MGS true duals JKRSDETROIT Intake and Exhaust 2 03-26-2012 01:06 PM
Map for 2011 103 RG, PCV, V&H pro-pipe, and SE air cleaner? sdlakerfan79 ECM/Fuel Management systems 4 12-28-2011 12:10 PM
Need Pcv map for 2010 FLTRX Garcou ECM/Fuel Management systems 4 10-20-2010 06:41 AM
