Neutral light on cruise not working and gear indicator not showing - Road Glide Forums
Tools and Garages Discussions related to working on your bike using your garage, your tools.
 2Likes
  • 1 Post By Shadow1
  • 1 Post By Xman247
post #1 of 8 (permalink) Old 07-11-2018, 10:38 PM Thread Starter
Xman247's Avatar
So tonight I noticed my neutral indicator light come on and off a couple times while riding around town. Shut the bike down for a bit then when took off again but neutral stayed and I could shift no problem. Then I checked cruise control and it was not working and the gear indicator position didn’t show either. Checked the neutral safety switch connectors and made sure they were clean but this didn’t help. I have read on some other forums it might be the neutral safety switch or the control switches on left side of handle bars. I have extended warranty so will take in hopefully they will fix this. Bike seems to run fine but checking to see if anyone else has had this problem and fix for same. 2016 RG Ultra. 22000 miles. Thanks
Update: Fixed!!! Neutral start switch for $24.00 and 5 minutes to swap out.
Xman247 is offline
post #2 of 8 (permalink) Old 07-29-2018, 01:25 PM
Where is the neutral start switch?
roadglide16 is offline
post #3 of 8 (permalink) Old 07-29-2018, 01:26 PM
I'm asking because I have the same problem.
post #4 of 8 (permalink) Old 07-31-2018, 08:29 AM
Originally Posted by Xman247 View Post
So tonight I noticed my neutral indicator light come on and off a couple times while riding around town. Shut the bike down for a bit then when took off again but neutral stayed and I could shift no problem. Then I checked cruise control and it was not working and the gear indicator position didnít show either. Checked the neutral safety switch connectors and made sure they were clean but this didnít help. I have read on some other forums it might be the neutral safety switch or the control switches on left side of handle bars. I have extended warranty so will take in hopefully they will fix this. Bike seems to run fine but checking to see if anyone else has had this problem and fix for same. 2016 RG Ultra. 22000 miles. Thanks
If you have this go out be aware your bike will not start in gear, I had mine choke out at a red light and it would not start until it was back in neutral, kind of a pain when in traffic.
BB Bomber likes this.
Shadow1 is offline
post #5 of 8 (permalink) Old 08-09-2018, 08:57 PM Thread Starter
Xman247's Avatar
Roadglide 16: Small switch on right hand side of case. Just above and slightly to the right of your tranny oil filler hole. About 3/4" diameter with two wires that go to it.
Xman247 is offline
post #6 of 8 (permalink) Old 08-11-2018, 10:06 AM
ChromeSpark's Avatar
'16 RGU & 27k miles and haven't had that happen, but good info to remember.
"It's a motorcycle, itīs not supposed to be comfortable, quiet or safe. The wind noise is supposed to hurt your ears, the seat should be hard and riding it should make you s**t your pants every now and then."
ChromeSpark is offline
post #7 of 8 (permalink) Old 08-11-2018, 11:04 AM
BB Bomber's Avatar
Had this problem too. But was a bad switch in the clutch lever pack. $200 fix. Thankfully was covered under warranty.
BB Bomber is offline
post #8 of 8 (permalink) Old 08-11-2018, 11:09 AM Thread Starter
Xman247's Avatar
The dealership i use original thought it may be the clutch lever pack as well. Turned out though to be much simpler. I swapped it out myself as the part was less than the deductible for my extended warranty.
Little Wing likes this.
Xman247 is offline
Neutral Light not working maddog094 *General Road Glide Discussions/Pictures 5 11-06-2017 01:58 PM
Rushmore Getting Wet -- Gear indicator display and cruise control issue SOLVED HighwayStar Controls & Handlebars 14 08-19-2016 04:39 AM
Red Key indicator on, turn signals not working... Historygeek888 Forum Help Desk (Post Forum Issues Here) 1 03-17-2016 09:46 PM
red cruise light, no cruise piggs Troubleshooting for Road Glides 1 05-08-2014 05:47 PM
Weird, Neutral indicator stops working after motor hot? JL Sargent Troubleshooting for Road Glides 2 07-10-2012 05:31 AM
