Chasing Threads - Road Glide Forums
Tools and Garages Discussions related to working on your bike using your garage, your tools.
 13Likes
post #1 of 17 (permalink) Old 03-23-2019, 06:12 PM Thread Starter
LS GLIDE's Avatar
Chasing Threads
How do you know what Thread pitch to use for chasing threads on the footboard or rear peg mounts, last time I removed them off another bike they were very difficult and seemed like they needed to be cleaned out before installing another set?
I don't have access to SnapOn or Mac, dealers, any suggestions?
'19 RGS
LS GLIDE is offline
post #2 of 17 (permalink) Old 03-23-2019, 07:17 PM
Get the bolt that fits it ,and measure between two crests. You can always do like I do ,if you have a kit. Grab one till it fits.
post #3 of 17 (permalink) Old 03-23-2019, 08:00 PM
Thermodyne's Avatar
You can look in the parts book and get the size of the bolt. But for what you mentioned, 3/8th and 5/16th course.
The holes will have thread locker in them. You should clean it out of the holes and off the bolts, then apply fresh blue locker.
Cheapest way to do it is with a wire bush like you clean you pistol with. Just chuck it up in a drill. Thread chasers work too. But a decent set is over 100 bucks.
Jacksprat56 likes this.
Thermodyne is online now
post #4 of 17 (permalink) Old 03-24-2019, 08:23 AM Thread Starter
LS GLIDE's Avatar
I don't mind spending the money on good tools, I just didn't know what set to buy, and how you can tell what pitch any given bolt is. So buy finding the size of the bolt that tells you what you need? That said, I;m sure the brush method will clean it up, because I don't think the threads are messed up, just have thread locker in them. Thanks
'19 RGS
LS GLIDE is offline
post #5 of 17 (permalink) Old 03-24-2019, 08:53 AM
MightyWhitey's Avatar
Your peg mounts are 3/8-16
For the most part you’ll find:
3/8-16
5/16-18
1/4-20
There is a couple of 7/16-14 and the brembo mount bolts are metric I believe.
MightyWhitey is offline
post #6 of 17 (permalink) Old 03-24-2019, 08:54 AM
https://shop.outpostalaska.com/OEMpartfinder.htm
Brewiz likes this.
post #7 of 17 (permalink) Old 03-24-2019, 05:35 PM
spray some brake or carb cleaner into the holes an use a wire brush to clean the threads. you shouldn't need a thread chaser unless the threads are actually damaged
post #8 of 17 (permalink) Old 03-25-2019, 08:21 AM Thread Starter
LS GLIDE's Avatar
MightyWhity thanks for the link
Therm, and riaf75 thanks for the tips , much appreciated
MightyWhitey likes this.
'19 RGS
LS GLIDE is offline
post #9 of 17 (permalink) Old 03-25-2019, 09:38 PM
Just get a 3/8 course tap (16 threads per inch) and run it through the holes to clean out the threads. You can get a single tap from most any hardware store for under $10
post #10 of 17 (permalink) Old 03-26-2019, 08:05 AM
That’s a cost effective alternative to an experienced hand. Put a new tap in an inexperienced hand and they’re likely to cut new threads and do more damage than anything else. Just sayin’
ChromeSpark and Buzzy like this.
Stripped out drain plug threads rlaf75 Troubleshooting for Road Glides 16 10-30-2015 10:44 AM
Not seeing subscribed threads JohnnyC Forum Help Desk (Post Forum Issues Here) 14 10-23-2014 08:09 PM
Participated in threads BravoInTX Forum Help Desk (Post Forum Issues Here) 1 09-24-2013 03:45 PM
Secret Society Threads OldNerdGuy *General Road Glide Discussions/Pictures 14 12-26-2010 08:55 PM
