Road Tech Install - Road Glide Forums
post #1 of 15 (permalink) Old 12-22-2013, 03:25 PM Thread Starter
Stag556's Avatar
Road Tech Install
I have a question about the road tech mount install. I'm trying to locate a good spot for power and ground. I have attached a pic for reference. The blue arrow points to two wires coming out of the headlight wires. Can I snip the ends off and connect the gps wires to these for constant power?
The red arrow points to what I believe is an accessory power point. Should I buy the accessory connector and connect to this for power?
Any help is appreciated. God forbid Harley include install instructions with the $600 GPS.
Stag556 is offline
post #2 of 15 (permalink) Old 12-22-2013, 03:51 PM
zemo1017's Avatar
There should be a lead in that bird's nest with an orange connector that is not used. It will power on with the ignition. The mating connector should be available at your local parts store. Used it for amp remote signal in the past. Manual is in storage since move so I'm going from memory.
zemo1017 is offline
post #3 of 15 (permalink) Old 12-22-2013, 03:52 PM
Banned
here try this link
http://www.americanbagger.com/pdf/hdzumogps.pdf
I would get the female end of the connector and use that
Sent from Motorcycle.com App
Scootin is offline
post #4 of 15 (permalink) Old 12-22-2013, 05:32 PM Thread Starter
Stag556's Avatar
Originally Posted by Scootin View Post
here try this link
That route seems like a lot more work then there needs to be. There's gotta be a connection inside the fairing. I thought about the cigarette lighter wires but figured I'd try to find wires that aren't used yet but still live.
Stag556 is offline
post #5 of 15 (permalink) Old 12-22-2013, 09:06 PM
I installed my unit via the included instructions. It does require removal of the tank console and running the power lead through the plastic wire tunnel. There is a spare place in the fuse block and an included wire with pin attached that will go right in the fuse block. This is for the positive lead and the ground simply goes to the battery. My unit powers on and off with the key lock switch.
ricerocketroaster is offline
post #6 of 15 (permalink) Old 12-22-2013, 09:16 PM Thread Starter
Stag556's Avatar
Those items came with the 660? I ask because I have no install instructions nor a supplied wire.
Stag556 is offline
post #7 of 15 (permalink) Old 12-22-2013, 09:42 PM
CSM11's Avatar
Look up the handle bar kit instructions, you will need a 5.00 jumper cable for the fuse box hook up. Simple install and was easy.
CSM11 is offline
post #8 of 15 (permalink) Old 12-23-2013, 08:24 AM
OKBigD's Avatar
I tested the wires where you placed the blue arrow. It is switched power, as soon as you turn the switch on it becomes hot. The Black wire is ground.
OKBigD is offline
post #9 of 15 (permalink) Old 12-23-2013, 09:02 AM
PGR
PGR's Avatar
Cigarette lighter wires, and a couple of T-taps. Red is switched hot, black is ground. Don't over think it.
Ron..........................
PGR is offline
post #10 of 15 (permalink) Old 12-23-2013, 09:16 AM Thread Starter
Stag556's Avatar
Awesome. Thanks. I was going to test them today but that saves me a step.
Stag556 is offline
Harley-Davidson Road Tech zūmo 660 and 665 Handlebar Mount Kit - Black longrides Classifieds Archive (3 months old+) 0 08-25-2011 09:48 AM
Road Tech Interface Module G Troubleshooting for Road Glides 11 08-01-2011 01:08 PM
fs - ROAD TECH XM SATELLITE RADIO RECEIVER cdcycle79 Classifieds Archive (3 months old+) 0 03-08-2011 08:05 PM
Trying to decided between Road Tech 660 and 665 G Audio 9 02-21-2011 08:30 PM
Deciding between Road Tech 660 & 665 - thoughts G *General Road Glide Discussions/Pictures 16 02-17-2011 12:55 PM
