TP wiring harness routing - Road Glide Forums
post #1 of 3 (permalink) Old 12-29-2013, 08:49 AM Thread Starter
Just installed the air wing luggage rack with LED lights on my king TP. Everything is hooked up except for routing the wires out of the TP and making the last connection. The instructions just say to drill a hole and install the grommet. But...where is the best place to drill the hole? It looks to me like it would be best to drill said hole in the middle but that would entail removing the metal plate on the bottom, but then I'm not sure if there is enough room for the harness. Just curious how/where you folks routed yours. My buddy with an Ultra-classic is out of town or I'd look at his. Thanks.
2011 RG Custom (Black Denim)
Magnum is offline
post #2 of 3 (permalink) Old 12-29-2013, 11:53 AM
My king TP has the wires exiting in the curved area where the lower backrest pad hangs. Light harness is on the riders left. http://partsfinder.onlinemicrofiche....R-PAK---BOTTOM Look up the TP bottom and you can see where the grommet is installed
DuraGlide is offline
post #3 of 3 (permalink) Old 01-01-2014, 12:58 PM Thread Starter
Thanks for the info. I went ahead and took the plate out of the TP drilled the hole in the middle. The most direct route. Works good for me. Happy new year!
Magnum is offline
Wiring a non ultra overlay harness Roadglider09 *General Road Glide Discussions/Pictures 7 04-16-2016 09:51 AM
Razor TP pad on Chopped TP? Uncle Fuzzy *General Road Glide Discussions/Pictures 9 07-01-2013 08:00 AM
Audio System Wiring Harness Wildman Classifieds Archive (3 months old+) 2 02-14-2012 07:52 PM
wiring harness for Classic style Tour Pak prince Lighting 4 01-20-2011 12:48 PM
Which Wiring Harness?? Lu Road Glide Specific Discussions 3 11-10-2010 08:02 PM
