'14 tourpak on a 13 RGC?? - Road Glide Forums
post #1 of 11 (permalink) Old 01-02-2014, 10:53 AM Thread Starter
longrides's Avatar
Why won't the '14 detachable rack fit a 13..... did the mounting points change?
If I buy the 13 detachable mount I'll have to drill holes in the tour pak.....
Has anyone done it?
Thanks
Currently Bikeless
Shopping for a '15 or '16 found one and it aint HD
2013 FLTRX Black Denim - 4" ceramic Jackpots, Fullsac X pipe header, PV w/FM map - gone but not forgotten
2008 Anniversary Edition,
gone but not forgotten.
longrides is offline
post #2 of 11 (permalink) Old 01-02-2014, 11:17 AM
NorCal's Avatar
the 2014 Tour-Pak and detachable rack does fit a 2013., I have mine on order through pc. Look at the below thread.
http://www.hdforums.com/forum/tourin...-tour-pak.html
NorCal is offline
post #3 of 11 (permalink) Old 01-02-2014, 11:27 AM
The question is if the color you need is available from Harley. Just got a pack but harley would not do the 14 pack in my 13 candy orange so I had to get the old style. Its much easier to get factory matched paint than have a painter match the candy orange.
HogPro is offline
post #4 of 11 (permalink) Old 01-02-2014, 12:37 PM
torqu's Avatar
Has anyone done it?
Thanks
Might want to PM SIC26. I believe he has a 2014 tourpack on his pre-2014 scoot.
torqu is offline
post #5 of 11 (permalink) Old 01-02-2014, 01:43 PM
4getNo1's Avatar
Maybe get a '14 Ultra Classic TP in Candy Orange and drill new holes in the bottom that retrofit that TP to a '13 mounting rack?
2013 FLTRX, Candy Orange
4getNo1 is offline
post #6 of 11 (permalink) Old 01-03-2014, 03:56 AM Thread Starter
longrides's Avatar
Thanks.... looks like it'll fit there are some that have done it. The dealer said yesterday it wouldn't ...
Now to look at the Motherwell rack as it's already black and has a lock.....
http://www.motherwellproducts.com/Pa...p/mwl-427b.htm
Currently Bikeless
post #7 of 11 (permalink) Old 01-03-2014, 04:05 PM
I have a 2004 Fiberglass tourpack on my 2011. The bottom was glassed in so it was flat and repainted. You'd never know.
Fortunately with the old ones being fiberglass they are probably a lot easier to work with and modify than the new ABS ones, or whatever that plastic is.
http://i1230.photobucket.com/albums/...rdon/photo.jpg
2011 RG Custom, Screaming Eagle Stage IV (260 Cam), Barnett Scorpion clutch, Hayden M6, Baker DD7, V&H Throttlepak, V&H Power Duals w/Hi-Output Slipons
115.4 ft-lb & 122.7hp : 1/4 Mile 12.542 @ 105.99 w/stock clutch and transmission
gbourdon is offline
post #8 of 11 (permalink) Old 01-03-2014, 08:17 PM
rossmann's Avatar
I have been thinking about doing the14 bags and trunk on my 11
rossmann is offline
post #9 of 11 (permalink) Old 01-03-2014, 08:57 PM
JJSW1283's Avatar
Do they not have different support brackets now? I could be wrong.
JJSW1283 is offline
post #10 of 11 (permalink) Old 01-03-2014, 09:08 PM
Side bags are same brackets/hardware. Just need a slight adjustment. Stealer removed mine and put a '14 side bag.
The '14 tour pack uses the same mounting points, docking hardware, using the new '14 bracket to mount the tour pack.
jethro_3 is offline
Looking for 13 tourpak adjustable relocation kit Bigmunkey Wanted! (Buy or Trade) 4 05-31-2016 09:18 PM
13 and under Tourpak lock with 15+ key help Steelerdude1 *General Road Glide Discussions/Pictures 6 01-11-2016 09:49 PM
Lighting for King Tourpak on RGC, presently no lights on it mmfinn Lighting 27 07-05-2013 07:20 PM
WTT Black Pearl Tourpak for Vivid Black Tourpak letsgofast Wanted! (Buy or Trade) 1 08-03-2012 01:54 PM
2010 RGC w/96 in Vivid black trade for 2011 RGC w/103 Sedona orange? bmayy71 *General Road Glide Discussions/Pictures 13 06-20-2011 04:54 PM
