Raise Front Fairing for Lowers - Road Glide Forums
post #1 of 16 (permalink) Old 03-02-2014, 11:20 AM Thread Starter
My uncle bought a 2000 RG and gave me his lowers. I test fitted them to my 2007 RG, the top of the lowers seem to touch the front fairing to where they won't wrap around the bar fully. I stopped by the dealership and they suggested that I might have to raise the front fairing. So my question is, how do I do this?
2007 RG FLTR
dinggus is offline
post #2 of 16 (permalink) Old 03-02-2014, 12:23 PM
Banned
2 ways :
The inner fairing has 4 bolts holding it to the mount. Access these by taking outer off and look toward the center behind all the wires. 2 bolts on each side, loosen them and raise up and bolt back.
2) - engine guard fairing mounts, loosen them and pull the back to raise up the outter portion of inner fairing. I would try this first
Sent from Motorcycle.com App
Scootin is offline
post #3 of 16 (permalink) Old 03-02-2014, 01:14 PM
mocotom's Avatar
Are these the non vented Roadglide specific fairings?
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #4 of 16 (permalink) Old 03-02-2014, 03:09 PM Thread Starter
Originally Posted by Scootin View Post
2 ways :
Will the front fairing have do go back down once I raise it?
Yes, non-vented. My cousin asked if I have after market crash bars, but I don't think I do. Came with the bike and looked like my uncles on his bike.
dinggus is offline
post #5 of 16 (permalink) Old 03-02-2014, 11:10 PM Thread Starter
Well, the left lower fairing goes into place, the right lower fairing doesn't and touches the front fairing.
2007 RG FLTR
dinggus is offline
post #6 of 16 (permalink) Old 03-02-2014, 11:24 PM
Bandit's Avatar
Technically they should fit. In regards to fitment of the Road Glide specific HD Non-Vented Lower Fairings, there is no differnce between the 2000 and 2007 model. The best thing I can recommend is, check Harley's website and verify that the fairings your Uncle gave you match the appearance of the ones in the catalog first. Or, post some pics of them. If I could see some pics, I could tell you if they "should" fit.
2005 FLTR - 97" S&S Big Bore, Hillside Cycle Stage II Heads & Throttle Body Upgrades, S&S Rollers, Fueling Pump & Lifters, 570G Gear Drive, TTS, CFR's, Klock Werks Double Back, 104hp/106ftlbs. CB's Euro, PM Light Glide LED Kit, RC CZar Wheels
Bandit is offline
post #7 of 16 (permalink) Old 03-02-2014, 11:50 PM Thread Starter
They are non-vented. What kind of photo's do you need?
I just test fitted the left one, and it fit perfect (I didn't mount it, but it didn't touch the front fairing).
dinggus is offline
post #8 of 16 (permalink) Old 03-03-2014, 08:21 AM
Bandit's Avatar
If your lower Fairings look like these.... they should fit. If they don't, something is either out of alignment or been changed.
File Type: jpg 35954380-b826-4e5a-97cc-de960f6f271e.jpg (15.7 KB, 49 views)
Bandit is offline
post #9 of 16 (permalink) Old 03-03-2014, 09:09 AM
Lower the crash bar, I did this on my old 01 SE RG and used "new style lowers" for 6.5 speakers.
Drilled new holes in the bottom and welded a tab on the top mount.
festus is offline
post #10 of 16 (permalink) Old 03-03-2014, 09:14 AM
HD makes a non vented fairing lowers for the batwing bikes HD part # 58830-88DH. The non vented fairing lowers for the batwing bikes are a little bigger and the fairing cap is larger than the non vented Road Glide Specific lowers HD part # 58841-98.
If the non vented fairing lowers are the Batwing style they will not fit your bike right unless the upper fairing is raised.
Raise Bike Up? Rambo Suspensions 15 02-13-2014 11:29 PM
Why do they raise the redline? DeneFLHR ECM/Fuel Management systems 4 12-30-2012 09:16 AM
Shocks to RAISE the rear? FLIronButtRider Suspensions 7 11-04-2012 10:35 PM
KObalt jack won't raise up from lock position jimmyray11349 *General Road Glide Discussions/Pictures 3 11-04-2011 08:19 AM
