Tour Pack Lighting Help - Road Glide Forums
post #1 of 6 (permalink) Old 03-04-2014, 07:17 PM Thread Starter
100edition's Avatar
I have an 03 RG with an HD Tour pack. I only have the side lights no rear lights on tour pack. I want to change the side lights to LED and maybe add a rear LED as well. I looked on Custom Dynamics site and looks like what they offer for 2002 to 2006 kit comes with corner lens as well as side. Question is can the corner lens be added without hacking up the TP? Any suggestions to any other brands? What do I need and does anybody have a part number? I recently added a BAL taillight and I am really wanting to brighten the TP as well.
100edition is offline
post #2 of 6 (permalink) Old 03-04-2014, 08:02 PM
RoadGlideRider's Avatar
First, on the older Tour Pak without the longer side lights, you can't add the newer side lights without cutting the bottom of the Tour Pak.
As for changing the lights to LEDs, I did it "On the Cheap". I went to the local WalMart. Found red LED strips (pair in each package). Unscrewed the 194 bulb sockets and measured the area. I cut the LED strip to fit and wired it in place under the stock lens cover.
A great improvement in lighting and didn't cost more than $15.
RoadGlideRider is offline
post #3 of 6 (permalink) Old 03-05-2014, 05:42 AM
dirtyb's Avatar
I know ebay has led tail lights simular to the H-D kit but way less money. I went with H-D because they didn't have smoked lenses and I've had bad luck buying things like that from ebay. However someone on here bought them and liked them so I think that might be your best bet. With the H-D kit you just had to drill mounting holes, it looks like the ebay kit would be the same. To me, it looks like the Custom Dynamics kit does not come with the bezel to go around the tail lights so you would have to add that.
link to ebay lights
http://www.ebay.com/itm/LED-Trunk-Ta...#ht_5326wt_867
2012 Road Glide CVO
2008 nightster (wifes ride)
2007 Street Glide Sold
2002 Heritage Sold
dirtyb is offline
post #4 of 6 (permalink) Old 03-05-2014, 05:52 AM
wjco9's Avatar
I put those lights on the tour pack used the Harley harness and hooked it up as run turn brake. Looks good and works great.
Jay
Live to Ride
Ride to Eat
wjco9 is offline
post #5 of 6 (permalink) Old 03-28-2014, 11:11 AM
Jay
Jay did you put the ebay lights on? If so hows the fit and finish any pics? I saw tose the other day and was thinking it may be worth a shot. Thanks.
Ed
rita883 is offline
post #6 of 6 (permalink) Old 03-28-2014, 01:40 PM
wjco9's Avatar
I did use the Ebay lights and wiring from Harley, made them run turn brake lights, love them, good fit. Use lots of painters tape, use the antenna holes to line it up. I did have to heat up the corners of the light and bend it in a little used the wires blow dryer. Use the instructions for Harley lights has all the parts listed. PM me if you need help.
Jay
Live to Ride
Ride to Eat
wjco9 is offline
Tour pack lighting 05Quadrasteer Lighting 0 04-07-2018 03:18 PM
Tour pak lighting Ron61 Aftermarket Accessories 34 04-18-2014 04:47 AM
tour pack lighting??? egiles Lighting 4 03-23-2014 06:53 PM
Tour Pak lighting - Quick Release Fillatre Lighting 5 06-22-2013 08:45 PM
Tour Pak lighting ThunderBueller *General Road Glide Discussions/Pictures 17 11-06-2010 04:51 PM
