Exaust - Road Glide Forums
post #1 of 7 (permalink) Old 03-12-2014, 01:11 PM Thread Starter
Exaust
Has anyone installed the COBRA Fi200 Power Pro Tuner?
vincepicone is offline
post #2 of 7 (permalink) Old 03-12-2014, 01:20 PM
I used the Fi 2000 on another bike I had and it work fine for what it is and I still have it. The Fi 2000 I have has the adjustable pods. A buddy of mine got one back a couple of years ago for his metric bike and it wasn't adjustable.
post #3 of 7 (permalink) Old 03-12-2014, 01:24 PM Thread Starter
Thanks
The description says it's an auto tune with no adjustments at all?
post #4 of 7 (permalink) Old 03-12-2014, 02:07 PM
The newer Fi2000 must all be auto tune by now. There are a lot of tuners out there so I would check around before buying. The Fi 2000 I had only hooked into the fuel injector harness so I do not know how the auto tune works on the new Fi2000. A tuner that works with the bikes ECM would be a better choice, Power Vision seems to be a popular tuners on the forum.
post #5 of 7 (permalink) Old 03-12-2014, 04:03 PM
sj01fltri's Avatar
I am running a cobra on my 2012 RG,decatted head pipe,SE air cleaner and rush slip ons,it does have some dip switches under the cover,hold the unit by the wires at the top and the body then twist,i have not had to adjust mine yet it works great for what i have done so far.
sj01fltri is offline
post #6 of 7 (permalink) Old 03-21-2014, 11:56 AM
I run the Cobra FI2000 Power pro on my 2013 FLTRU. It works fine and adjusts to any mechanical, intake, exhaust modification. It also adjusts to elevation. It takes a couple secends to read the desired fuel mixture on startup, so I had to change the way I start the engine. Instead of letting the bike go through its diagnostics, I push the start button while the fuel pump is still sounding right after I turn on the ignition switch.
Spock
2013 FLTRU
Spock is offline
post #7 of 7 (permalink) Old 03-21-2014, 06:15 PM
sj01fltri's Avatar
I just installed a Thunderheader,on thur,took it for a ride today,the tuner works great,seems to have picked up a little umph over decatted head pipe and rush slip ons.
Exaust System Change? Your Thoughts..... Nevadasun Intake and Exhaust 6 06-04-2015 08:04 PM
Stock exaust gaskets or SE Howardsternspenis Intake and Exhaust 4 06-07-2013 07:32 PM
Exaust fitment question braymond52 Intake and Exhaust 4 06-25-2012 01:08 PM
R and B racing exaust Misplaced Intake and Exhaust 8 03-25-2012 10:51 AM
