Distance between tour pack mount and rear seat bolt.... - Road Glide Forums
post #1 of 9 (permalink) Old 10-12-2014, 01:46 PM Thread Starter
SEUGOT1's Avatar
Can anybody that is running a Harley-Davidson or Motherwell detachable tour pak mount and runs two-up, measure the distance between the front of the rack (not the tour pak) and the rear seat bolt?
Mine seems to be farther back than some as my tour pak is sitting back on the rack which is showing in the front....thanks
2018 FLTRXSE, Freedom 13" windshield, SOUNDZ amp, Iron 65 fairing & lower speakers, Iron 57 saddlebag speakers, Fullsac MX pipe, CVO power cores, Corbin dual touring seat, Ohlins 159 shocks, JH Choppers Performance floorboards, Pingel floorboard extenders, King tour pak w/chopped backrest, Metalsport luggage rack, Ciro3d cupholders, Avon grips
SEUGOT1 is offline
post #2 of 9 (permalink) Old 10-12-2014, 06:51 PM
It's tough to get a precise measurement, but I've got 2" - 2 1/4" from seat screw to the front of the detachable mount base. Mine is a Harley Quick Detach Mount if it matters.
2012 FLTRX, vivid black
sometimer is offline
post #3 of 9 (permalink) Old 10-12-2014, 06:55 PM
93-331-29psi's Avatar
The Harley tour pak has two sets of holes for mounting the tour pak. It's possible yours is mounted on the rear set. Changing this may make things better.
93-331-29psi is offline
post #4 of 9 (permalink) Old 10-12-2014, 07:06 PM
The front edge of the mount is flush with front edge of my TP and 1 1/2" to 2" back from the seat screw. Tough to get an exact measurement. HD mount and mounting points.
DuraGlide is offline
post #5 of 9 (permalink) Old 10-12-2014, 07:39 PM
My TP sits well ahead of the mount using the forward holes. I know there are kits to set the TP even further back than the two standard positions. Maybe this is the case with the OP's Tour Pack?
post #6 of 9 (permalink) Old 10-13-2014, 07:39 PM Thread Starter
SEUGOT1's Avatar
I am running the Motherwell detachable rack and was wondering why part of the rack was showing, I do have the TP mounted back somewhat to give my wife room to move around. I don't think mine is that close to the seat bolt......its 1 3/4" appr, so the HD rack must sit even farther back?
SEUGOT1 is offline
post #7 of 9 (permalink) Old 10-13-2014, 07:55 PM
Depends on the year of the Tour Pac too. My 13 TP bottom is relatively smooth and sits flush with the front edge of the mount. I have an older chopped TP and the bottom has half-moon sections to use a round tube as part of the mount. On the detach mount, it has to set back probably 1.5" from the front edge of the mount to sit flat.
post #8 of 9 (permalink) Old 10-14-2014, 04:54 PM Thread Starter
SEUGOT1's Avatar
Mine is an '09 I believe, it is not flat on the bottom and has the 1/2 moon shaped ridges towards the back and side, so I could only mount it in one position.
SEUGOT1 is offline
post #9 of 9 (permalink) Old 10-14-2014, 07:15 PM
Yeah, my chopped TP sits further back on the bike for that very reason. Just guessing, about 1.5" further than the king TP I have without the 1/2 moon ridges on the bottom. Front edge of the mount is showing with the chopped, flush with the king.
mold between tour pack and badkrest dawgrgc1 Paint & Bodywork Section 2 02-21-2017 03:18 PM
06 dealer takeoff seat has 1/2" gap between seat and console on my 02 chevjerico Seating: seats, backrests 7 10-30-2013 11:17 AM
best long distance seat for big guys ? rob883 Seating: seats, backrests 24 05-08-2013 11:42 PM
10" Windvest. front and rear turn signals. Rear mount and pegs and highway peg mount. 1346wildcat Parts for Sale 10 04-23-2013 06:34 PM
WTB: 2 up detach tour park mount and solo tour pak mount for 09+ bikerglasses Wanted! (Buy or Trade) 2 04-01-2013 10:22 AM
