Front Brake Lever - Road Glide Forums
post #1 of 10 (permalink) Old 10-18-2014, 06:43 PM Thread Starter
Q-Hog's Avatar
Front Brake Lever
How much play should be felt when squeezing the front brake lever?
Q-Hog is offline
post #2 of 10 (permalink) Old 10-18-2014, 06:52 PM
Measuring from the end of the throttle grip to the inside end of the brake lever (ball) I have around 3 1/2 inches, when the brake lever is pulled in until it stops without force I have 2 1/4 inches.
About a 1 1/4 to 1 1/2 inches of travel should be normal.
post #3 of 10 (permalink) Old 10-18-2014, 08:15 PM Thread Starter
Q-Hog's Avatar
My lever is very hard. I'm under and inch or less.
Q-Hog is offline
post #4 of 10 (permalink) Old 10-18-2014, 08:48 PM
Do the brakes seem to work properly?
rlaf75 is online now
post #5 of 10 (permalink) Old 10-18-2014, 10:03 PM Thread Starter
Q-Hog's Avatar
It works. It's that all I have to do it barely squeeze the lever and it stops. BTW, I have a single rotor set up. It feels like I should have a little be more pullback on the lever before it fully stops. Thx.
Q-Hog is offline
post #6 of 10 (permalink) Old 10-18-2014, 11:06 PM
not sure if it has anything to do with your issue but I know the bikes with only brakes on one side from the factory have a smaller piston /bore size than the touring bikes with two caliper setup, the single use a 9\16 the dual use an 11\16 .
The larger bore may give you less lever travel with only one caliper since it would take less fluid to move the pads to the rotor now
Eagle is offline
post #7 of 10 (permalink) Old 10-18-2014, 11:29 PM Thread Starter
Q-Hog's Avatar
Ok. Thx...
Q-Hog is offline
post #8 of 10 (permalink) Old 10-19-2014, 06:15 AM
93-331-29psi's Avatar
Definitely the issue. Find a softail front master cylinder and all will be normal again.
93-331-29psi is offline
post #9 of 10 (permalink) Old 10-19-2014, 10:27 AM
Some Dyna models also have single sided brakes .
Eagle is offline
post #10 of 10 (permalink) Old 10-19-2014, 12:03 PM Thread Starter
Q-Hog's Avatar
Thx.... Will do.
Q-Hog is offline
Lever Change Kuryakyn Boss Lever 16RGS *General Road Glide Discussions/Pictures 9 03-31-2017 09:45 AM
front brake lever adjustment ckl2007 Controls & Handlebars 2 08-25-2014 06:23 PM
Front brake lever switch longrides Troubleshooting for Road Glides 21 03-11-2013 09:40 PM
Billet brake lever installed for rear brake HUTMO Do-IT-Yourself 1 12-27-2012 03:18 PM
Brake Lever ohd24 Equipment-RG 3 01-30-2012 03:11 PM
