ACC switch - Road Glide Forums
post #1 of 9 (permalink) Old 04-22-2015, 07:10 PM Thread Starter
ACC switch
I'm looking for ideas for what I can do with the acc switch. I just bought the harness from iron aces cuz well for $15 I figured I can use it for something right. What is everybody using that switch for?
post #2 of 9 (permalink) Old 04-22-2015, 07:25 PM
RGKen's Avatar
I have my Motolights hooked up to it.
2018 FLTRXS
RGKen is offline
post #3 of 9 (permalink) Old 04-22-2015, 07:27 PM
sfcusaret2004's Avatar
i have my heated hammock seat hooked up to it with the under seat connector. I believe the acc pigtail coming off the main headlight harness also is controlled by this switch.
sfcusaret2004 is offline
post #4 of 9 (permalink) Old 04-22-2015, 07:52 PM Thread Starter
I haven't looked yet but I believe the iron aces harness plugs in under the seat. Not 100% sure.
post #5 of 9 (permalink) Old 04-22-2015, 09:03 PM
Running fogs, most run highlights (groundworks) around here, some direct to battery
reds4 is offline
post #6 of 9 (permalink) Old 04-22-2015, 09:37 PM Thread Starter
I was thinking about the penny finders.
post #7 of 9 (permalink) Old 04-23-2015, 08:32 AM
hd4cruzin's Avatar
I have my Iron Aces iPhone adapter and Corbin heated seat connected.
2012 FLTRX BBP
hd4cruzin is offline
post #8 of 9 (permalink) Old 04-23-2015, 12:54 PM
Stick_FSMC's Avatar
Bought the parts and built my own harness.
I use it to power the garage door opener (switched power - ACC/Ignition on) from a button on my dash.
https://www.roadglide.org/showthread.php?t=1335
and the driving lights (ACC Switch on the Dash)
https://www.roadglide.org/showthread.php?t=17766
Stick
USAF 1980-84
Stick_FSMC is offline
post #9 of 9 (permalink) Old 04-24-2015, 04:19 PM
I use the stock one for a USB charger that kills my FM reception when it's on so I wired it to the switch. I added a second one to the left hand side because I hated the blank and run a mo-door garage door opener off it. Also have the splitter under the seat so can add other accessories as needed.
roadie13 is offline
Muting the radio- ACC Switch Puff-N-Stuff Tech Area 20 04-05-2013 11:07 PM
Checking if acc switch was connected at moco jacksonfdny *General Road Glide Discussions/Pictures 10 10-02-2012 06:26 AM
My ACC switch does't work ????? jacksonfdny *General Road Glide Discussions/Pictures 2 09-30-2012 12:41 PM
ACC switch question ODA CDR (RET) Controls & Handlebars 3 05-24-2012 06:40 AM
2010 ACC switch h-donut Audio 2 04-05-2011 10:21 AM
