Do Saddlebag Locks Have Plastic inside? - Road Glide Forums
post #1 of 4 (permalink) Old 04-30-2015, 07:44 AM Thread Starter
Shark of the Month September 13
JRB_RME5's Avatar
Hi all,
I figure someone will know -
I want to powder coat the two locks off my RG saddlebags ('13). I need to make sure the lock has no plastic in the lock (just the lock) as it will, of course, melt during the process.
Thanks ahead of time.
Josh
JRB_RME5 is offline
post #2 of 4 (permalink) Old 04-30-2015, 09:11 AM
Are you referring to the saddlebag latches or the locks on the latches?? From what I can tell both are made of metal. The reflectors in the latches are plastic but they are just stuck on with 2 sided tape and can be removed.
post #3 of 4 (permalink) Old 04-30-2015, 12:04 PM
SurlyBoy's Avatar
I just took the locks and latches apart last night to swap the cylinders. I did not see any plastic inside the lock cylinder.
SurlyBoy is offline
post #4 of 4 (permalink) Old 05-17-2015, 11:16 AM Thread Starter
JRB_RME5's Avatar
It can be done. roger at final touch powder coat (spring lake, nc) did em. Key works fine. He did the hinge also and is fine. Now, the entire saddlebag assembly is viv black.
JRB_RME5 is offline
Saddlebag locks screw size? HogPro *General Road Glide Discussions/Pictures 6 11-28-2013 01:54 PM
Do you think I can mount this amp inside my fiaring? sdlakerfan79 Audio 6 03-22-2013 02:42 PM
Check your saddlebag locks!! laxinharley Do-IT-Yourself 12 07-06-2012 02:22 PM
Do You Have a Strong Mind....Well Do Ya??? Nevadasun General Off-Topic Discussions 17 02-12-2012 10:22 AM
Best saddlebag locks ??? THEMASTERDESTROYER Aftermarket Accessories 9 11-28-2011 05:37 PM
