Tour Pak Lid Organizer - Road Glide Forums
post #1 of 5 (permalink) Old 06-02-2015, 04:30 PM Thread Starter
Andyman's Avatar
I just ordered one from New Castle HD. PN 53249-01B
I have an air wing tour pak rack and want to bolt the organizer to the lid. Is there a template out there- anyone have one- that I can use to drill the holes to get this thing lined up perfectly?
'03 Deuce: 90k miles and counting, '11 RGU: 80k miles and counting.
Andyman is offline
post #2 of 5 (permalink) Old 06-02-2015, 06:21 PM
sj01fltri's Avatar
Well you could always remove the tour pac rack,then using the double sided tape place it where you want it,then close the lid,place masking tape around the holes,then drill the holes in the organizer using the rack holes.
sj01fltri is offline
post #3 of 5 (permalink) Old 06-02-2015, 11:01 PM
arkieglide's Avatar
This is the technique I used and it worked well. I would add to use over-sized washers against the organizer so the screwheads don't pull through.
2011 RG Ultra Brilliant Silver Pearl
arkieglide is offline
post #4 of 5 (permalink) Old 06-02-2015, 11:20 PM
tdkkart's Avatar
The organizer has plastic stiffening panels inside the back side, you'll be drilling through these to get the bolts back in from inside the organizer's pockets.
It's a bit of a 3-handed job, but it works great once it's done. I've did the same with the saddlebag rails and those organizers also.
tdkkart is offline
post #5 of 5 (permalink) Old 06-03-2015, 03:09 AM Thread Starter
Andyman's Avatar
Cool, y'all. Thanks for the tips!
Andyman is offline
Best method to retain the TP Lid Organizer bigsixman Equipment-RG 4 11-30-2015 12:22 PM
King Tour Pack Lid Organizer RRHartzler Aftermarket Accessories 7 11-21-2015 07:58 AM
Tour pac lid organizer walledog Parts for Sale 10 06-02-2015 04:26 PM
Top Shelf Tour-pak Organizer Easyryder01 Sold 6 05-02-2013 10:00 PM
***WTB *** Tour-Pak felt liner and/or organizer SharkNose Classifieds Archive (3 months old+) 1 01-20-2011 11:43 PM
