2001 lowers on 2015 - Road Glide Forums
post #1 of 20 (permalink) Old 06-28-2015, 07:34 AM Thread Starter
Bender15's Avatar
2001 lowers on 2015
I did some trimming and just want some opinions on fitment.
The left side needed trimmed where it meets the upper fairing. And the right side fits perfect. Just real close. I can see light between where it meets the upper fairing. Just want an opinion.
Bender15 is offline
post #2 of 20 (permalink) Old 06-28-2015, 07:37 AM
RGKen's Avatar
The fairing sopport brackets have a slot in them where they bolt to the fairing to allow for some up and down movement if I remember correctly. You may have been able to loosen the one side and push the fairing up then re-tighten.
Also... If you loosen the brackets where they mount on the engine guard you can move them a little side to side and that can move the fairing by a small amount too.
2018 FLTRXS
RGKen is offline
post #3 of 20 (permalink) Old 06-28-2015, 07:48 AM Thread Starter
Bender15's Avatar
I tried that and it didnt move much. Thanks tho
Bender15 is offline
post #4 of 20 (permalink) Old 06-28-2015, 09:16 AM
Something doesn't look right because you should have a equal gap between the fairing lowers and the upper fairing.
Which 2001 lowers are you using??
To move the upper fairing you may have to take off the outer fairing and loosen the inner fairing bolts.
post #5 of 20 (permalink) Old 06-28-2015, 10:26 AM
r_einan's Avatar
Are those the vented or non vented lowers? I have a set that I haven't tried to put on my '15 yet.
r_einan is offline
post #6 of 20 (permalink) Old 06-28-2015, 11:32 AM Thread Starter
Bender15's Avatar
Non vented
From an Ultra. So is my upper fairing lower on one side stock?
Bender15 is offline
post #7 of 20 (permalink) Old 06-28-2015, 11:33 AM Thread Starter
Bender15's Avatar
Front shot
Bender15 is offline
post #8 of 20 (permalink) Old 06-28-2015, 11:48 AM
r_einan's Avatar
Your fairing might be slightly different from one side to the other. OR it could be that the lowers are mounted slightly different, they don't have a precise positioning system.
Mine are the vented lowers that are supposed to fit through '13. I haven't gotten around to mounting them yet; I haven't decided if I want to change the fairing supports or cut the caps. If I can get there in the next couple days I will let you know how it turns out.
r_einan is offline
post #9 of 20 (permalink) Old 06-28-2015, 02:35 PM Thread Starter
Bender15's Avatar
That would be awesome. I'm ready to send these to paint. I got it trimmed and set up and don't think it looks bad at all. Just never installed lowers and was curious why the one side needed trimmed.
Bender15 is offline
post #10 of 20 (permalink) Old 06-28-2015, 02:41 PM
RGKen's Avatar
If your lowers will fit through 13' they will fit through 15'. The engine guard hasn't changed. Just FYI.
2018 FLTRXS
RGKen is offline
2015 Street Glide wheels on a 2001 Roadglide. Bamaglider Wheels and Tires 23 04-13-2015 05:56 AM
Let us go back to 2001 Wooden Nickel *General Road Glide Discussions/Pictures 10 03-17-2011 01:25 PM
2001 screaming eagle stock seat panhead Classifieds Archive (3 months old+) 0 10-17-2010 07:28 PM
Looking for a 2001 Road Glide seat. Perfucto Classifieds Archive (3 months old+) 9 09-27-2010 10:16 AM
Lowers, lowers and more lowers Garemlin *General Road Glide Discussions/Pictures 57 05-11-2010 09:18 PM
