Extended Floorboards and Brake Pedal - Road Glide Forums
 5Likes
post #1 of 20 (permalink) Old 01-26-2016, 03:05 PM Thread Starter
RRHartzler's Avatar
I'm thinking of buying the "Extended" Floorboards and the Brake Pedal for my 2004 Road Glide. I am 6' 3" and I have a 35" inseam. I have found the Glide to be a little cramped and thought this might help.
Anybody have any experience with these Harley parts?
I have a bundle of "Points" from the dealership that comes to around $250.00 and thought this would be a great addition.
RRHartzler is offline
post #2 of 20 (permalink) Old 01-26-2016, 04:26 PM
Nordic Berserker's Avatar
Check out tall boys cycle floorboard relocation brackets tallboyscycles.com or kuryakyn floorboard relocation brackets, 1" out & 1" forward, can also be used with Harley extended floorboards.
I also recommend walters workshop extended shifter arm waltersworkshop.com & softbrake.com or
E-ZBrake.com for extended brake levers.
Nordic Berserker is offline
post #3 of 20 (permalink) Old 01-26-2016, 05:06 PM
SurlyBoy's Avatar
I have the kuryakyn board relocators. Love them. I'm considering the Es-brake as well
SurlyBoy is offline
post #4 of 20 (permalink) Old 01-26-2016, 06:59 PM
x2 on the tall boys cycle brackets. i came off a fat bob with forwards to a 15 road glide and the stock board location was really bothering my hips at 6'4. got the brackets and a +3 brake pedal from softbrake. very comfy now.
Hematite likes this.
thegardner is offline
post #5 of 20 (permalink) Old 01-27-2016, 08:11 AM Thread Starter
RRHartzler's Avatar
Thanks for the input.
post #6 of 20 (permalink) Old 01-27-2016, 11:08 AM
Bigfoot's Avatar
a little more roomy....
I used the Kuryakyn floorboard brackets (moves 'em 1" up & 1" out), the Kuryakyn extended shift lever and the brake lever. I'm 6'6" and wear size 14 boots. The Kuryakyn brake lever puts the pad further out and lower. To install it I had to loosen the lower fairing support in order to rotate the lever onto the shaft. Just for comfort I also permanently removed the vents to prevent my toes from hitting them. I also removed the heel shifter lever to make room for my big feet! If you use the Kuryakyn heel shift eliminator it also moves the shifter out a little. It works for me.
RFG7680 likes this.
BigFoot
2013 FLTRU
PGR of Arizona,Tucson Javalinas RC
Bigfoot is offline
post #7 of 20 (permalink) Old 02-01-2016, 11:07 AM
MightyWhitey's Avatar
Can anybody share pics of the kury's and the tall-boys installed? Also looking to relocate. Thanks.
MightyWhitey is offline
post #8 of 20 (permalink) Old 05-25-2016, 06:15 AM
Chrisg81983's Avatar
Second that thanks in advance.
Chrisg81983 is offline
post #9 of 20 (permalink) Old 05-25-2016, 07:20 AM
Kury 1 and 1 on the floorboards and the kury extended break pedal. Don't have any before pics to do an exact comparison but you can compare to your position. Both work just fine with lowers.
Docshaun is offline
post #10 of 20 (permalink) Old 05-25-2016, 12:33 PM
Thanks that looks good it looks like it laid the break pedal down closers to the floor boards in the end. Is that the case or just the pic.
Sent from my SM-N920T using Tapatalk
Tags
brake pedal , extended , floor boards
Black streamliner floorboards, brake pedal, footpegs JPROADGLIDE Parts for Sale 5 03-02-2018 08:38 AM
streamline floorboards, grips, brake pedal Swagzilla Parts for Sale 3 02-11-2016 08:26 AM
Bars, FloorBoards, Pegs, Peg Mounts, Brake Pedal, Winshield EZ2012CVO Parts for Sale 23 07-21-2013 01:29 AM
Extended +2 Brake Pedal Robare Parts for Sale 1 06-14-2013 05:06 PM
Kuryakyn extended brake pedal on 2011 RGU Steve Controls & Handlebars 0 07-10-2011 01:19 AM
