2008 Tour-Pak on a 2015 RGS - Road Glide Forums
post #1 of 9 (permalink) Old 03-27-2016, 04:58 PM Thread Starter
I found a '97 to '08 Harley King Tour-Pak locally on craigslist for $200. It's black cherry, but good enough for my purposes. It came with the '97 to '08 detachable rack (53303-07A). I bought the H-D Detachables Two-Up Tour-Pak Mounting Rack (53000221) to fit my mounting system ($120 on ebay).
I removed the old mount and found ridges on the bottom that would not allow my new rack to lay flat against the TP.
I used the 2015 quick detach mount as a template for the hole locations. I drilled four new holes (1/4 inch) into the floor of the TP. I used neoprene washers against the paint and stacked metal washers on top of that to offset the rack so that it would clear the ridges and mount securely.
Came out alright. More pics in the following posts.
glop06 is offline
post #2 of 9 (permalink) Old 03-27-2016, 04:59 PM Thread Starter
More pics.
glop06 is offline
post #3 of 9 (permalink) Old 03-27-2016, 05:04 PM Thread Starter
Pics.
glop06 is offline
post #4 of 9 (permalink) Old 03-27-2016, 05:05 PM Thread Starter
Lots of room! Might plasti-dip it to match.
glop06 is offline
post #5 of 9 (permalink) Old 03-27-2016, 05:16 PM
immo2896's Avatar
where there's a will, there's a way. Good job making it fit. What about interference with the opening of the lids on the bags?
immo2896 is offline
post #6 of 9 (permalink) Old 03-27-2016, 05:54 PM
lil chief's Avatar
I just put an 09-13 pak on mine using the 09-13 detachable mount. No spacers between pak and rack. The lids come close, but they clear.
Lil Chief
lil chief is offline
post #7 of 9 (permalink) Old 03-27-2016, 06:07 PM
Smarty's Avatar
What a lot of peeps do to mount this is get some fuel rubber hose in 3/8" or 1/2" and place the hose in the place the old tour pack was. Put some silicon in the slot to seal the holes and then drill like you did. The hose becomes the rubber bushings basically and makes for a solid evened out load on the tour pack.
2016 RGS Black Quartz
Smarty is offline
post #8 of 9 (permalink) Old 03-27-2016, 09:38 PM Thread Starter
Bags clear. Barely.
glop06 is offline
post #9 of 9 (permalink) Old 03-28-2016, 01:55 AM
Really cool. I kinda have the same situation but the box sits back pretty far on the rack showing about 2" of plate. I was looking for a solution to it so I'm glad I got to see this one. Thanks
suomy1 is offline
Razor Tour Pak On A 2015+ RGS Swomack Aftermarket Accessories 41 12-26-2016 12:36 PM
2015 RGS Tour Pak add on question Ronstopable *General Road Glide Discussions/Pictures 6 04-26-2016 12:06 PM
metalsports tour pak rack on a 14 tour pak? longrides Aftermarket Accessories 0 11-05-2014 09:15 AM
2008 Tour Pak on a 2015? Sethjamto *General Road Glide Discussions/Pictures 11 09-11-2014 07:59 PM
WTB King Tour Pak or Chopped Tour Pak- BLACK jimmyray11349 Classifieds Archive (3 months old+) 0 06-03-2011 10:29 AM
