vent won't close - Road Glide Forums
 3Likes
  • 1 Post By bucketlisthd
  • 1 Post By lil chief
  • 1 Post By Texas Rapier
post #1 of 8 (permalink) Old 10-30-2016, 04:14 PM Thread Starter
Question vent won't close
i can't close the right vent in the fairing. the open & close lever/switch is stuck flush or open????anyone know what to do or do i call the dearler??
nanook is offline
post #2 of 8 (permalink) Old 10-30-2016, 04:27 PM
bucketlisthd's Avatar
If you repeatedly push the button, I think that it will close. My vents are finicky also. Fairing is coming off this winter. I will see about lubing the mechanism.
Jacksprat56 likes this.
bucketlisthd is offline
post #3 of 8 (permalink) Old 10-30-2016, 05:10 PM
lil chief's Avatar
The service manual indicates that the vent mechanisms should be inspected, cleaned, & lubed every so often. It's just a spring type mechanism that's susceptible to dirt.
Lil Chief
lil chief is offline
post #4 of 8 (permalink) Old 10-30-2016, 07:28 PM
Smarty's Avatar
Take the outer fairing off and you will be able to see the mechanism. Blow it out with air, then take graphite, not WD 40 or some other lubricant and shoot it into the area that clicks and holds it open. You don't want anything that will soak up the dust and dirt and speed up the sticking again. Pretty simple fix and Harley used to change out the mechanism under warranty.
2016 RGS Black Quartz
Smarty is offline
post #5 of 8 (permalink) Old 10-31-2016, 12:49 PM
Swomack's Avatar
I had that happen to me a while ago on my 2015 RGS.
Took it to the dealer and they replaced a bad part on the right side. Took them 15 minutes for the fix once they received to new part. Havent had any issues since the fix last year.
Swomack
My Gallery / Click Below Link
Swomack is offline
post #6 of 8 (permalink) Old 10-31-2016, 06:57 PM
twowheeladdict's Avatar
One of mine won't stay open. Wish it was stuck open. No reason to close the vents. Will let the dealer fix it.
twowheeladdict is offline
post #7 of 8 (permalink) Old 11-04-2016, 08:55 AM
teejay's Avatar
Had my left one replaced under warrantee.
tom
teejay is offline
post #8 of 8 (permalink) Old 01-29-2017, 03:04 PM
Texas Rapier's Avatar
I have had mine stick a couple of time. I have removed the fairing, cleaned and lubed them and the issue seems to persist. What I have discovered is these latched don't respond well to brute force but better to a light touch.
I have found that lightly pressing in you will feel the ratchet lock disengage and the vent will close. and visa verse.
1 2 many likes this.
2018 Road Glide Ultra (Electric Blue)
Retired Coast Guard Chief Engineer.
Texas Rapier is offline
Close call. Real close! dreeves *General Road Glide Discussions/Pictures 38 04-25-2017 01:23 PM
Vent options for pre 2010 Lowers Tytanium Aftermarket Accessories 8 12-28-2010 07:34 PM
... is it me or what? (VENT) mr4teth General Off-Topic Discussions 4 07-28-2010 06:42 PM
Clearview GT large tinted with vent JacktheBagger Windshields 5 06-03-2010 12:37 AM
Vent your Speeding Ticket here! DreamRider *General Road Glide Discussions/Pictures 27 05-29-2010 10:06 AM
